a good cat
yes I did a search. only found out that no body likes carsound cats anymore.
any new info? decided to go with kamikaze headers, *insert brand* cat, Apex'i dunk (already have).
you will be close on emissions...and you might fail....you will hear a difference in the top end....it also eliminates the buzzing sound of the exhaust (sometimes)....
in most areas you will probably FAIL emissions testing if you try to pass with a straight pipe. the cat. converter (i abreviated cus i cant spell! HA!) is pretty much what makes you pass/fail...
You will fail emissions and it will be loud as hell.
Just had mine replaced with a test pipe and I can barely hear my girlfriend unless she yells while accelerating.
Also my exhaust just started buzzing ...anyway to fix this?
Just had mine replaced with a test pipe and I can barely hear my girlfriend unless she yells while accelerating.Also my exhaust just started buzzing ...anyway to fix this?
It thought they would still pass emissions just have a higher flow of air let through??? Anyways you can try http://www.optauto.com they have them there for my year for 200
I had a carsound but returned it, they were nice, but no better than random IMO, also the randoms have the o2 bung and WILL pass emmisions, from experience, i have the aq printout to prove it... i'm pretty sure carsound will too, but it would require welding and custom fit, also not ideal if your obd2
I have an OBDI car and I had it done with my swap so they had to chop up my exhuast anyway. Otherwise I don't think Hi-flow cats are going to add much power unless the old one is clogged. The 2-3hp gained is probably not worth the B.S. and cost on a OBDII vehicle unless you do a OBDII workaround.
cyrix12
Aug 16, 2006 03:24 PM
YellowR2000x2
Apr 8, 2003 01:22 PM
