ecu looking for a pressure switch, and my solenoid is missing it.
the gsr is a jdm and the solenoid only has one plug the vtec one...the ecu is looking for the pressure switch...is this preventing vtec from kicking in?
also when i check A4 pin witha voltmeter it is constantly powered? is this correct?
will vtec kick with out the pressure switch?
Modified by Dead CIVIC at 1:10 PM 7/13/2008
if the ecu is looking for the vtec pressure switch and you don't have one get another vtec solinoid that does, some JDM B series vtec engines do not have a vtec pressure switch and the corresponding ECU doesn't look for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">if the ecu is looking for the vtec pressure switch and you don't have one get another vtec solinoid that does, some JDM B series vtec engines do not have a vtec pressure switch and the corresponding ECU doesn't look for it.</TD></TR></TABLE>
yeah i'm trying to find one, and im curious to know it the vtec should still be engaging?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">should be throwing a CEL and not engaging, someone correct me if i am wrong</TD></TR></TABLE>
yeah it is throwinng a CEL and not engaing. so then i need the solenid that comes with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">if you are running a us ecu then yes you need the us vtec solenolid that has the solenoid wire and the vtec pressure switch</TD></TR></TABLE>
cool tanks for that... do i need to buy the ex harness or will running the wires work.?
Takumi Fujiwara
Jul 23, 2006 09:18 PM
