need wide front fenders asap
Old Jul 13, 2008 | 03:14 AM
hyabusa hunter's Avatar
Default need wide front fenders asap
hey all
i need to find somewhere that offers wider fenders for the front of my lude, i cant fit my new drags under the OEM fenders
so any help would be great or if there a way i can modify the OEM ones?
Old Jul 13, 2008 | 07:09 AM
h23prelude's Avatar
you can try rolling you factory fenders with a rolling tool that attaches to your lug studs, i'm not sure if that will give you enough clearance or not, but its worth a try.
have you removed your fenders to see if the wheels will fit around the knuckle, brakes, etc.. then you can get a good idea of how much they will stick out of the fender well too
Old Jul 13, 2008 | 10:19 AM
Default Re: (h23prelude)
yea the wheels bolt up nicely, they clear eveything bar the fenders, once the car is off the jack the frnder rests on the tire. the tire sticks out about an inch, i can all work iif i jack the suspension up and inch or so, but i dont really wanna do this
Old Jul 13, 2008 | 10:59 AM
lude98SH's Avatar
Default Re: (hyabusa hunter)
what size tires are those ?
Old Jul 13, 2008 | 11:55 AM
Kronn 98SH's Avatar
Default Re: need wide front fenders asap (hyabusa hunter)
http://cgi.ebay.com/ebaymotors...l1116
Old Jul 13, 2008 | 11:56 AM
Default Re: (lude98SH)
they are 255/50/16
Old Jul 14, 2008 | 05:02 AM
Default Re: need wide front fenders asap (Kronn 98SH)
i guess i should have mentioned in the 1st post, i have a 4th gen lude, im looking for something i can revit on really, i dont want to much hassle with filling and painting
Old Jul 15, 2008 | 10:19 AM
im thinking of getting a 240sx carbon wide fender kit cause the measurements are almost the same, ill get it to fit
Old Jul 15, 2008 | 10:39 AM
NirVTEC's Avatar
Very curious about the setup youre using those for.....I hope youre making alot of power......
Do you really need flares?
Old Jul 15, 2008 | 12:15 PM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Very curious about the setup youre using those for.....I hope youre making alot of power......</TD></TR></TABLE>
x2
those tires are wicked tall. by calculation, the increased diameter will give you the same overall drive ratio as if you had a 3.90 FD on stock diameter tires.
Old Jul 15, 2008 | 12:43 PM
Rosko's Avatar
Default Re: need wide front fenders asap (vlang29)
those look huge! what does that diameter figure out to be??
Old Jul 15, 2008 | 12:48 PM
vlang29's Avatar
Default Re: need wide front fenders asap (Rosko)
26.04" dia... vs 23.88 stock. that's over 9% increase
Old Jul 15, 2008 | 02:10 PM
the tire diameter is 25.8
the way we figured it was im crossing the line hitting the rev limiter in 4th gear and i was using BFG T/A DRAG radials then 225/50/15, so to make the gear ratio longer we decided to use a taller tire (please correct me if im wrong) so we go thro the line just before rev limit in 4th
im pushing 529hp
plus im adding a bit of laughin gas at the next track event
the reason i need fender flares is because the tire sticks out an 1" and when the car is lowered down off the jack, the fender rests on the tire, i dont really wanna jack the suspension up an inch or so.
Modified by hyabusa hunter at 3:16 PM 7/15/2008
Old Jul 15, 2008 | 02:18 PM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">im pushing 529hp</TD></TR></TABLE>
lol you do need rubber then!! hahah
it will be very noticeably geared taller, should help you put power down in the earlier gears too because the taller tires actually slightly lower the amount of torque that reaches the pavement
Old Jul 15, 2008 | 07:35 PM
Finest's Avatar
Your best bet is a combination of raising the front, cutting the fenders around an inch around the edges, and roll them in. Even if you can get your suspension jacked up in the front to clear the tires, what happens when you're at the backend of the track and on the brakes hard?
Old Jul 15, 2008 | 09:46 PM
Default Re: need wide front fenders asap (Finest)
the car is street driven aswell, so i want to do a half decent job of it, i am going to have to cut the fenders anyhow cause i dont wnna keep adjusting the hieght every time i put my street tires on. maybe im just being a fuss
but if i have the wider fenders then i can leave it at the hieght it is now and swap over the wheels with no hassle really
Old Jul 15, 2008 | 10:47 PM
ludeboi121's Avatar
maybe adding some fender flares? if you that you can cut the fender and have the flares clean things up
Old Jul 16, 2008 | 09:31 PM
Default Re: need wide front fenders asap (ludeboi121)
i thinks thay gonna be the way to go, just need to find some decent flares
b17power
May 8, 2013 08:31 PM
lspecz
Feb 11, 2007 11:34 AM
tunedek
May 31, 2004 10:09 PM
bigTom
Jan 12, 2003 01:03 AM
Brian Samoa
Jul 17, 2001 03:55 AM
