is my vtec solenoid supposed to have only one plug. 95 gsr.
Old Jul 12, 2008 | 09:54 PM
Dead CIVIC's Avatar
Veteran: Army
Default is my vtec solenoid supposed to have only one plug. 95 gsr.
well the vtec is not engaging the ecu is throwing a code for the pressure valve?
but there is no plug for the pressure valve, it only has the solenoid plug? do i need to get a solenoid that as it?
Old Jul 12, 2008 | 10:17 PM
BlueIntegraBoy's Avatar
Default Re: is my vtec solenoid supposed to have only one plug. 95 gsr. (Dead CIVIC)
The oil pressure switch is below the VTEC solenoid.
Old Jul 12, 2008 | 10:19 PM
Turbo(less)DB8's Avatar
Sounds like a JDM type r vtec solenoid. They do not have the oil pressure switch.
Old Jul 12, 2008 | 10:39 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: is my vtec solenoid supposed to have only one plug. 95 gsr. (Turbo(less)DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The oil pressure switch is below the VTEC solenoid.</TD></TR></TABLE>
yeah bur it's not there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo(less)DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a JDM type r vtec solenoid. They do not have the oil pressure switch.</TD></TR></TABLE>
when i drive the car the vtec dies not engage. but it does do something when it hits 5.5.
could it be cause idt doesn't have the oil pressure switch that it is not fully engaging...the ECu is looking for it.
Old Jul 12, 2008 | 10:41 PM
JDM engines don't have the pressure switch, USDM ECUs look for it. Can't have both. You can bypass the switch though.
Old Jul 12, 2008 | 10:54 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: is my vtec solenoid supposed to have only one plug. 95 gsr. (BlueIntegraBoy)
so if the ecu is looking for it than is better to just ge a new solinoid that has both and hook it up...will it work then?
also is there i should use or does everyone jsut run the wires and add the plugs?
Old Jul 13, 2008 | 10:57 AM
Dead CIVIC's Avatar
Veteran: Army
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">so if the ecu is looking for it than is better to just ge a new solinoid that has both and hook it up...will it work then?
also is there i should use or does everyone jsut run the wires and add the plugs?</TD></TR></TABLE>
bump cause i need help.
Old Jul 14, 2008 | 02:01 AM
you can just run the wire. It's commonly done. However, your gsr harness should already have plug. BTW, you are hearing your secondaries open up at 5500.
raidacaipo
May 10, 2008 09:36 PM
blueeg
Apr 25, 2006 11:16 AM
jdmsiR20
35
Apr 3, 2005 01:32 AM
ViXoN Hatch94
May 7, 2004 02:10 PM
insomniac791
Jun 7, 2003 08:56 AM
