89 honda civic si d16a6 hesitant when pressing gas & code 10 and 14?
I have a slight hesitant problem when I am going steady on the steady throttle it hesitates mostly while on the throttle.
for the codes I am getting 10 and 14. I checked the sensor and its giving 5 volts just like the manual says I tired a new sensor, new ecu, and distributor.
still same problem.. any ideas wtf is causing this just started happening few days ago.. check spark plugs all look good..
Well 10 is your IAT(intake air temperature sensor) and 14 is your IAC( idle air control valve).
Now you can buy a new idle air control valve here
http://www.partsamerica.com/Pr...Set=A
But as you can see its 200 bucks. May want to find a used one there.
Next your air temperature sensor you can find here
http://www.partsamerica.com/Pr...50091
As you can see its 50 dollars. You may want to find this part used also. I hope this helps.
OBTW I looked these parts up using the motor code you gave me d16a6. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellsLikeMustand »</TD></TR><TR><TD CLASS="quote">I have changed the IAT already...</TD></TR></TABLE>
Hmm, Idk then. You might need to unplug your battery for acouple mins or so to reset the ecu. Have you tried that yet?
I have tired to reset the ecu by doing that also. I am think something is wrong in the electrial system. not sure..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellsLikeMustand »</TD></TR><TR><TD CLASS="quote">I have tired to reset the ecu by doing that also. I am
Ehh, well I am out of ideas. Electail system is not my favorite thing. Good luck though!
</TD></TR></TABLE>Ehh, well I am out of ideas. Electail system is not my favorite thing. Good luck though!
anyone have this problem code 10 and 14?
anyone know if the code 10 and 14 are some how interconnected in the wiring somewhere?
can it be something else that is throwing the two codes like something else is [freak]ed up..?
[freak]ing pissing me off stupid car..
I think its the injectors still have a little hesistant when starting in first gear. I tired some hf injectors and those didn't work...
i would A)get some injector cleaner or run high octance gas
B)clean out your iacv and make sures the hoses are all tight and hooked up(you could have a little vacuumm leak?) just my 2 cents goodluck
beedoublejay
Aug 21, 2005 03:28 PM
CsiRUN
10
Aug 6, 2005 12:17 PM
Red_Si
23
Jan 24, 2004 11:04 AM
