changed tail lights, now brake lights don't work
Old Jul 19, 2002 | 08:32 PM
Scary1109's Avatar
Default changed tail lights, now brake lights don't work
well i installed new tail lights on my integra, and now my brake lights (3rd brake light and tail brake lights don't work) along with my horn.... i have no clue what happened, but i sure would like to hear of anyone who's had this prob before.
TIA
Scary
[Modified by Scary1109, 12:37 AM 7/20/2002]
Old Jul 19, 2002 | 09:01 PM
Scary1109's Avatar
Default Re: changed tail lights, now brake lights don't work (Scary1109)
it is blowing the 20 amp fuse for the horn and the brake lights, what the f*@k??? anyone know what i did wrong?
1am is not a good time to do car mods.
Scary
Old Jul 20, 2002 | 05:44 AM
Scary1109's Avatar
help.....anyone???
Old Jul 20, 2002 | 06:09 AM
Chiovnidca's Avatar
Scary
Is this a preexisting condition, or did it start after replaceing your bulbs or lenses? Has the car ever been an accident?
Old Jul 20, 2002 | 07:06 AM
Scary1109's Avatar
Default Re: changed tail lights, now brake lights don't work (Chiovnidca)
it just started after i put the new lights in, it only blows the 20A fuse when i hit the brakes. if i don't hit the brakes, the horn works fine, as does everything else
Scary
Old Jul 20, 2002 | 07:46 AM
Chiovnidca's Avatar
Did you replace the bulbs or the lenses. Recheck your work. Did you use the right bulbs? Is there a bare or pinched wire? It should be easy to find the problem.
Old Jul 20, 2002 | 07:51 AM
Scary1109's Avatar
the bulbs are fine, i just pulled the lenses out, (i replaced the stock ones) i am gonna check for any wires that are pinched now.
Old Jul 20, 2002 | 09:15 AM
Scary1109's Avatar
well i did indeed smash a brake light wire, between the body and the mounting bolt, thanks for the help, my car no longer blows fuses when i hit the bakes
-Scary
Old Jul 20, 2002 | 09:36 AM
Chiovnidca's Avatar
[QUOTE]well i did indeed smash a brake light wire, between the body and the mounting bolt, thanks for the help/QUOTE]
I hate it when that happens.
blkbond8065
Aug 27, 2015 02:34 PM
Spoogen_1
Aug 2, 2010 08:57 AM
jansem
Jul 21, 2004 08:27 PM
