14 inch tires
Old Jul 12, 2008 | 02:30 PM
Dekorum's Avatar
Default 14 inch tires
Is there a way to get low profile 14 inch tires? I need new tires for my OEM wheels and since my car is lowered I want some smaller aspect ratios because I rub a little bit as is. Is 60 or 55 the smallest? If so, there is no true low profile 14"...
Old Jul 12, 2008 | 03:20 PM
addiction2bass's Avatar
Default Re: 14 inch tires (Dekorum)
where are the tires rubbing? or are you not willing to rock negative camber?
ive never heard of rubbing on 14 stock steelies.LOL
Old Jul 12, 2008 | 04:58 PM
itsmejto's Avatar
If you go lower profile you will loose speedo calibration and will have the effect of lower gearing your final drive and also reduce your gas milage and cause the engine to rev a little higher to make the same speed. Sounds to me like you lowered it too much.
Old Jul 12, 2008 | 07:14 PM
Dekorum's Avatar
I don't have the stock steelies. I have some honda option wheels. I am raising the back a little so I don't rub the wheel well at all, but besides that, I kind of want some lower profile tires anyway. Is there a such thing?
Old Jul 13, 2008 | 08:05 AM
itsmejto's Avatar
Default Re: (Dekorum)
Usually you would need to go larger in diameter to a , say 16" or 17" wheel and use a 35/40 profile tire. Youll get that "bicycle tire " look. Not for me, but if it floats your boat, go for it. Either way, you need to adjust your suspension height to clear.
96teggynonVtec
May 31, 2006 05:21 AM
Spunkster
Nov 16, 2004 09:49 PM
DIP_SET FoReVr
Feb 26, 2004 04:01 PM
Austinbionic316
15
Feb 7, 2004 09:31 AM
Vracer111
Feb 19, 2003 09:41 AM
