CRX radio problem....
So my CRX if you read my recent posted died on me, but I got her running back again with brand new parts all over
. But anyways now my new problem is my radio isn't working. When car died I checked all fuse and everything else, no blown fuse-didn't see any. Replaced my main relay is only fuse type I replace and a will be getting a new ground cable/wire soon-everything else is engine related and replaced-up and running.
So in order for my radio to work what else controls the radio/power? Where else can I look or do or redo to check to find and fix my problem? Well let me know thanks.
. But anyways now my new problem is my radio isn't working. When car died I checked all fuse and everything else, no blown fuse-didn't see any. Replaced my main relay is only fuse type I replace and a will be getting a new ground cable/wire soon-everything else is engine related and replaced-up and running.So in order for my radio to work what else controls the radio/power? Where else can I look or do or redo to check to find and fix my problem? Well let me know thanks.
well is it stock or aftermarket? many aftermarket radios also have a fuse on the wires behind the unit or plugged into the back of the unit. check there.
it's an aftermarket one...just looked but i'll have to open the cd/radio player right? and look for it? Cuz on the back is just plugs/wire no fuse so must be inside then....let me know....
well I opened it anyways not all of it,but just enough to see inside and damn I didn't even know I left a cd in there
But anyways nawh it had worked before when the car was running and since it died and got fix haven't been able to turn it on since...so anything else on car I should look for again or anything? Or is this it new radio and see what happens? LMK
