o2 sensor help, D16y8 please help
hey i'm trying to clear my check engine light. the problem was o2 sensor bank 1 sensor 1 which is closest to the engine. I replaced the o2 sensor and found the old one had 3 exposed wires and i assumed they were touching. I tried to clear the code in every possible way i could (negative, back up fuse, ecu, scan tool). And it will always come on. Might the o2 sensor messed up the ecu by those wires touching?
its throwing it. i am trying to clear it nowm but it always comes back on. and there is no possible way to get rid of it. i think the ecu might be messed up but not really sure. i dont have that much time to chat cause i am on trial version right now.
If the same O2 sensor code is being thrown after clearing the ECU, then the O2 sensor circuit probably still has a bad wire. Repairing O2 sensor wiring is a tricky business.
A bad ECU is possible, but typically pretty rare. I recommend that you first carefully recheck all the wiring with a multimeter (voltages and continuity). If your original repair involved cutting wires in the O2 circuit, those repairs should involve soldering.
I sent you an instant message (HondaTech address).
Check the downloadable 96-98 Civic manual for details -- chapter 11, pgs 11-84 to 11-94.
Your scan tool should prove very useful for the troubleshooting, if you have reasonable one.
hey thanks for all the help, but it was the ecu, i put my friends 2000 ex ecu and it cleared up the CEL and never came back on. i drove it for about 2xx miles already. i traded my si rims for his ecu and his rota group n
phbrush
27
Dec 17, 2014 07:25 AM
anothersickhatch
May 15, 2004 10:22 PM
crxtreme27
Sep 19, 2002 02:01 PM
DreamSpeed
Jan 13, 2002 11:29 PM
