1st turbo start up
So finally its finished and dropped into the car on Thursday and by late Friday we started the engine 1st time.
The engine kept reving low-high / low-high by it self which meant an air leak somewhere. I suspect the EVAC but didn't get chance to check it as had to leave to work. Turbo was dropping small tiny dropplets of oil right from the centre and last we couldn't get the laptop to find the drivers for the S300 ECU (it plugs and says new hardware found but no matter what it won't find the drivers off the disc) the mechanic had S300 stuff on there before but it must be old and I told him install the software of the CD 1st before you connect the ECU but he did anyway.
I'll update once go in Monday early morning and see what's happening but everyone says to me if the engine started 1st time then the rest is easy to fix.
B16a2 Engine with the following:
Head:
- Skunk2 valves
- Skunk2 dual valve springs
- Skunk2 titanium retainers
- Skunk2 intake manifold
- Skunk2 Pro stage 1 camshafts
- Skunk2 adjustable cam gears
- 0.5mm skim to raise compression up
Block:
- Darton sleeves (81.25 bore)
- SRP 8:2:1 pistons
- Eagle rods
- ACL racing main and rods bearings
- Balanced crank, flywheel, clutch and pully
Fuel:
- RC 750cc injectors
- Skunk2 carbon fuel rail
- AEM fuel pressure regulator
- Walbro fuel pump
- Custom braided fuel line
- B&M fuel pressure gauge
Turbo:
- Garret T3/T4 57 trim, 63a/r
- Pfabrications stainless log manifold
- Goodridge oil feed & return kit
- 38mm external wastegate
- 51mm blow off valve
- 2.5" intercooler piping all round
- Mishimoto G-Line front mount intercooler
Transmission:
- ACT Pro light flywheel
- ACT 408 lb/ft clutch kit
- JDM import transmission with standard LSD
EMS:
- P30 ECU with Hondata S300 + boost control + GM 3 bar map sensor + GM boost solneiod
Other parts include thermal intake & throttle body gaskets, new water pump, high flow oil pump from a type r, OEM headgasket, NGK E11 spark plugs, Spit fire spark leads, stepper motor boost/oil pressure/water temperature gauges.
I'm sure I have missed few parts as usual ..
Modified by yakuza at 2:08 PM 7/12/2008
Head:
- Skunk2 valves
Block:
- SRP 8:2:1 pistons
- Eagle rods
Fuel:
- Walbro fuel pump
Turbo:
Transmission:
EMS:
I don't disagree at all, but still the car shouldn't rev like this. I'm not talking just a light tone, its reving from like 800-1000 RPM to 2000 or over and then goes down. Too much high RPM and to do such high rev it must be getting air from somewhere without the TB been open !!!
I'm off to the garage in an hour or two anyhow as I haven't seen the car since Friday, will be on it all day and see what we will be able to do in whole day on it.
h kid
25
May 22, 2005 06:57 PM
93LSivic
Aug 7, 2002 09:12 AM
