Anyone using Drain Plug Oil Temp Sensor
Old Jul 12, 2008 | 06:29 AM
RStoR's Avatar
Default Anyone using Drain Plug Oil Temp Sensor
Is anyone using the drain plug sensor location? Would like to see a picture of it mounted. Particularly how far is sticks out and how low it is in relation to the bottom of the pan.
Please don't post "weld a bung in"! I want to explore all options before making a final decision.
Thanks!
Old Jul 12, 2008 | 06:46 AM
Tweakmeister's Avatar
Default Re: Anyone using Drain Plug Oil Temp Sensor (RStoR)
Another option is the Greddy sandwich plate on the oil filter. You can run a pressure sensor here as well.
Old Jul 12, 2008 | 06:50 AM
RTW DC2R's Avatar
i ran one for awhile then just decided to tap the pan instead. it didnt stick out too far, figure about an inch or so out from the drain plug, perpendicular to the drain plug, not straight down, so clearance wasnt really an issue. but it did make for a bit of a PITA to remove the plug to drain the oil.
disregard the other **** I had in here lol
Modified by RTW DC2R at 10:55 AM 7/12/2008
Old Jul 12, 2008 | 07:00 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (RTW DC2R)
If you're using the drain bolt hole, why do you need a picture? It'll look just like the drain plug with a wire sticking out of it.
Old Jul 12, 2008 | 08:28 AM
baonest's Avatar
Default Re: (Stinkycheezmonky)
weld a bung in
Old Jul 12, 2008 | 02:47 PM
EleanoR's Avatar
Default Re: Anyone using Drain Plug Oil Temp Sensor (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">Another option is the Greddy sandwich plate on the oil filter. You can run a pressure sensor here as well.</TD></TR></TABLE>
Chris this is what I did and have been very happy with it. I too run the temp and pressure sensors off this adapter. I run the coolant sensor off the upper radiator hose (Greddy adapter that slips in the hose).
mike
Old Jul 12, 2008 | 05:55 PM
cmdr430's Avatar
weld a bung in...sissy
break that new "bling" in the right way......
Old Jul 13, 2008 | 12:44 PM
Ketone's Avatar
Default Re: Anyone using Drain Plug Oil Temp Sensor (cmdr430)
I did have an oil drain plug oil temperature sender on my car, but I thought it hung too low and I got tired of the wiring getting twisted every time I took the drain plug off to change the oil. Sorry I don't have any pictures, but those are my experiences with it.
Old Jul 13, 2008 | 12:58 PM
Ultraspeed DC2's Avatar
does anyone have the dipstick style sensor? i saw one here a long time ago but couldn't get any more info on it
Old Jul 13, 2008 | 08:55 PM
Devon M's Avatar
I have a mint Greddy oil plate that ill sell yah!
jokellum
Honda Civic (2001 - 2005)
Jan 13, 2015 02:18 PM
98bwahhek
12
Feb 7, 2013 09:04 AM
Hiboost 2.0
Transmission & Drivetrain
Sep 9, 2011 11:39 AM
mish__
Nov 16, 2010 07:52 PM
vannak_5415
Oct 6, 2008 05:34 PM
