HELP... my car is running wierd
Old Jul 12, 2008 | 12:35 AM
darksolguy's Avatar
Default HELP... my car is running wierd
ok so here is a short story.... i had a b18c in my car .. then i gt pulled over got a ref ticket so iwent back to sohc..... i swapped everything in .. everything seemed to be fine. it started and then i drove it.. it felt nasty... i pushed the gas and it reacted weird,,,, it took a long as time to react and it was running retarded... then i turn off the car and then turn it on and it turns off on its own.... i changed internals in the dizzy and it work again but still running like ish..... anyone have an idea...
<U>GOT IT RUNNING.... does anyone know the color if the wires from the engine harnes that go to the crank sensor.... my plug got cut so i have to use another plug thats not the same color.</U>
Modified by darksolguy at 7:48 PM 7/13/2008
Old Jul 12, 2008 | 12:55 AM
darksolguy's Avatar
Default Re: HELP... my car is running wierd (darksolguy)
this is what i have checked so far
battery ; spark plugs and wires - ground- ecu- the fuel pump does prime,,
Old Jul 12, 2008 | 01:18 PM
darksolguy's Avatar
come on ht help me out
Old Jul 12, 2008 | 01:21 PM
ek_si hatch's Avatar
when u changed the internals did u brake it in??
Old Jul 12, 2008 | 06:34 PM
darksolguy's Avatar
Default Re: HELP... my car is running wierd (ek_si hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_si hatch &raquo;</TD></TR><TR><TD CLASS="quote">when u changed the internals did u brake it in??</TD></TR></TABLE> what do u mean by break it in.....
Old Jul 12, 2008 | 06:38 PM
JdelMsolG's Avatar
throwing any cels?
and, no need to "break in" the internals of a dizzy haha.
Old Jul 12, 2008 | 11:01 PM
darksolguy's Avatar
Default Re: HELP... my car is running wierd (JdelMsolG)
how can i check?
Old Jul 12, 2008 | 11:39 PM
Memnoch's Avatar
Are you throwing any check engine lights?
And did you double check your firing order?
Old Jul 13, 2008 | 12:50 AM
darksolguy's Avatar
no check engine lights and i check the firing order like 1000000000000000000000000000 times... lol
Old Jul 13, 2008 | 04:39 AM
JdelMsolG's Avatar
check air filter, fuel filter, oil filter?
Old Jul 13, 2008 | 06:46 PM
darksolguy's Avatar
yes ...!!!!!!!! got it working... it was the coil.... its throwin a check engine.... code is 54... its a crankcensor.... does any one know the color if the wires from the harness that goes to the crank sensor plug...... thanx........
wendeln16
Jun 27, 2013 11:36 AM
MIND SET
Aug 18, 2011 01:33 PM
Jimster480
13
Feb 12, 2010 07:58 AM
0618turbocivic
Jul 9, 2006 08:31 AM
