car wont start!!!
Old Jul 11, 2008 | 08:31 PM
lazypnoy808's Avatar
Default car wont start!!!
got a 92cx..after checkin everything me n my couzin concluded it was the starter relay..come to find out after goin out n buyin a new one..its not WTF! wat seems to be the problem?? thnx..
Old Jul 11, 2008 | 08:35 PM
happycorey's Avatar
Default Re: car wont start!!! (lazypnoy808)
Could be main relay, ecu fuse, grounds. Is it priming? Is it turning over?
Old Jul 11, 2008 | 08:38 PM
Default Re: car wont start!!! (happycorey)
no it wont..the only reason we said it was the relay was bcuz we bypast the relay itself n it turnd over..
Old Jul 11, 2008 | 09:15 PM
Former User's Avatar
Is the starter switch at the top of the clutch pedal bad?
Old Jul 11, 2008 | 09:28 PM
Default Re: car wont start!!! (RonJ@HT)
im pretty sure it alrite...n if thts it then wat must be done??
Old Jul 11, 2008 | 09:31 PM
Check it and, if necessary, repair or replace.
Old Jul 11, 2008 | 09:36 PM
well ima check tht out tomorrow..jus got dark here lol.freakin thing was alrite when i first gotta it..starting fine then all of a sudden it wont..
Old Jul 11, 2008 | 09:42 PM
Old Jul 12, 2008 | 07:10 AM
happycorey's Avatar
Or just cut the wire so you can strat your car without the clutch
Old Jul 12, 2008 | 07:14 AM
team_exceed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happycorey &raquo;</TD></TR><TR><TD CLASS="quote">Or just cut the wire so you can strat your car without the clutch</TD></TR></TABLE>
lol. great idea. you remind me of my friend ben... a jerry riggin sob!
Old Jul 12, 2008 | 07:20 AM
happycorey's Avatar
Default Re: car wont start!!! (team_exceed)
I usually don't, but sometimes it's just easier to cut the wire
Old Jul 12, 2008 | 07:38 AM
Just be aware that, by cutting the wire, you are losing an important safety feature.
Old Jul 12, 2008 | 06:37 PM
wat wire???
Old Jul 13, 2008 | 12:54 AM
happycorey's Avatar
Clutch engagement start feature.
However, starting it in first is soooooooo tight. Just starting it and driving away, no clutch
madego
Nov 20, 2013 07:05 PM
91tegrals
Feb 12, 2012 09:03 PM
dc4b20
Jun 20, 2009 06:09 PM
jax si
May 25, 2005 03:35 AM
