Power dies after 5500rpm, d16 with s300.
Old Jul 11, 2008 | 07:34 PM
justinCO's Avatar
Default Power dies after 5500rpm, d16 with s300.
I just went to get a simple baseline pull on the dyno today before I install all my turbo stuff. I ended up with 68whp @ 5400rpm and 68ft.lbs. torque.
It looks ok (for a d16) until ~5500rpm when the power just falls to the ground. I have the datalog of the pull and was trying to find out what is wrong if I could, just for the sake of learning.
The setup is, d16y8 block w/ z6 head, wiseco/eagle bottom end, around ~8.7:1 compression, y7 stock exhaust, otherwise stock engine. s300 with untouched stock p28 calibration other then revlimit/idle adjustments.
Here is the infos:
http://jackmoves.com/~justin/datalog-stock-7k.s3d
Any ideas? I can upload my calibration too if needed, but it is just the p28 one that comes with Hondata s300.
Justin
Old Jul 12, 2008 | 08:27 AM
mtber's Avatar
Default Re: Power dies after 5500rpm, d16 with s300. (justinCO)
What map sensor are you using ?
Your log is showing 12 psi at 5200 rpms etc...
Are you using a wideband ?
Old Jul 12, 2008 | 09:23 AM
justinCO's Avatar
Default Re: Power dies after 5500rpm, d16 with s300. (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">What map sensor are you using ?
Are you using a wideband ?</TD></TR></TABLE>
Stock map sensor, engine is still in stock n/a form. I have a hondata 4bar for boost (which I bought from you guys actually, along w/ my 1000cc RC's )
12psi where? I am at altitude too (5280ft) so 12.6psi or so is atmospheric.
I did not pay for wideband on this pull since there will be no tuning on this setup. It was just to get a before turbo baseline #. I knew the power would be weak, but I at least expected the car to pull through to 7200rpm redline as opposed to 5500rpm and pooper out.
Justin
Old Jul 12, 2008 | 09:26 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinCO &raquo;</TD></TR><TR><TD CLASS="quote">
I did not pay for wideband on this pull since there will be no tuning on this setup. It was just to get a before turbo baseline #. But I at least expected the car to pull through to 7200rpm redline as opposed to 5500rpm and pooper out.
Justin</TD></TR></TABLE>
1. Calibrate the map sensor to your altitude.
2. Use a wideband to monitor your air fuel ratios.
Old Jul 12, 2008 | 09:35 AM
Tomdata's Avatar
High altitudes will not show false pressure readings. The higher the altitude the lower the barometric pressure. Your map sensor should be showing a little vacuum @ WOT because of the high altitude. Even though technically there is not any vacuum in the manifold because there barometric pressure is too low to get the 0"vacuum reading you would get @ sea level. If your datalog shows 12 PSI and you have a stock map sensor then you probably have the wrong sensor selected in you S300. Are you sure it is set for a stock map sensor and not a gm 3bar?
As for the power drop off... what is the AFR during the dyno pull? Are you sure it isn't going pig rich because the ecu thinks its @ 12 pounds of boost?
Old Jul 12, 2008 | 09:36 AM
justinCO's Avatar
2. Use a wideband to monitor your air fuel ratios.</TD></TR></TABLE>
Do you have to do something other then selecting the correct MAP sensor in Smanager? I'll take another look.
Yes, wideband will be used of course when it goes in for the "real" tuning once turbo stuff is all installed. I will not be tuning the car btw, my local tuner will be...even though I (street) tuned my old car on old hondata stage4 system.
Thx,
Justin
Old Jul 12, 2008 | 09:45 AM
justinCO's Avatar
Default Re: Power dies after 5500rpm, d16 with s300. (Tomdata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata &raquo;</TD></TR><TR><TD CLASS="quote">High altitudes will not show false pressure readings. The higher the altitude the lower the barometric pressure. Your map sensor should be showing a little vacuum @ WOT because of the high altitude. Even though technically there is not any vacuum in the manifold because there barometric pressure is too low to get the 0"vacuum reading you would get @ sea level. If your datalog shows 12 PSI and you have a stock map sensor then you probably have the wrong sensor selected in you S300. Are you sure it is set for a stock map sensor and not a gm 3bar?
As for the power drop off... what is the AFR during the dyno pull? Are you sure it isn't going pig rich because the ecu thinks its @ 12 pounds of boost?</TD></TR></TABLE>
Yea, that's why I asked where the 12psi was. 'Cause I see a little vacuum at WOT myself. I don't see positive manifold pressure anywhere in my log?
Yes, I have the "Stock MAP Sensor" radio button selected in Smanager.
No AFR's for this one It very well might be going rich beyond 5500rpm, I had thought about that too.
Thanks for infos.
Justin
Old Jul 12, 2008 | 09:17 PM
SOHC_MShue's Avatar
Post your calibration. Your datalogging is reading 12psi positive manifold pressure
Old Jul 13, 2008 | 12:15 AM
justinCO's Avatar
Default Re: Power dies after 5500rpm, d16 with s300. (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Post your calibration. Your datalogging is reading 12psi positive manifold pressure </TD></TR></TABLE>
http://jackmoves.com/~justin/p28-breakin-map.skl
So, what am I reading wrong? I didn't see 12psi anywhere, so I must be reading something incorrectly or not have a value showing on my graph?
Thanks for looking.
Justin
Old Jul 13, 2008 | 07:48 AM
SOHC_MShue's Avatar
ahh your settings must have been set for absolute pressure. I guess on hondata the graph seems to still read in whatever unit settings it was originally logged in. I figured if i changed it in the program it would reflect that in the units.
Old Jul 13, 2008 | 09:17 AM
justinCO's Avatar
Yea, you'd see about 12psi absolute at this altitude WOT.
Old Jul 17, 2008 | 07:54 PM
Sr420Det's Avatar
So I downloaded the datalog and was wondering why do I see a AF ratio that doesnt get above 12. If he didnt have a wideband should I be able to see any readings. I also noticed his iat stayed the exact same over a 30 second period.
Old Jul 27, 2008 | 12:29 PM
justinCO's Avatar
Default Re: (Sr420Det)
Here is an interesting thing I found out yesterday. The bolt that seals the inspection hole in the head next to where vtec solenoid is, was found just sitting in the head when I took off the vc
Think this had anything to do with the problem? Maybe vtec was not working?
Justin
aeon117
Engine Management and Tuning
Jun 4, 2017 09:05 PM
sydtren
10
May 30, 2013 07:05 AM
crxb16a90
15
Sep 5, 2009 07:55 AM
is3oo
May 17, 2004 09:34 AM
