Purge solenoid
Old Jul 11, 2008 | 06:20 PM
javon972's Avatar
Default Purge solenoid
im in the middle of installing my d15b vtec right now we broke the dame Purge solenoid do i really need it will it throw a code
Old Jul 13, 2008 | 07:44 AM
94EG8's Avatar
Seagull Management
Default Re: Purge solenoid (javon972)
If your running a P08 you don't need it at all, if your running a P28 i'd highly recomend that you get one. I'm not sure if it will throw a CEL, but i've been told that the engine wont idle correctly without it, just go to a junkyard and get one off a D15B7 or something.
Old Jul 13, 2008 | 10:38 AM
coupej1's Avatar
i would get one no matter what ecu u are running.
Old Jul 13, 2008 | 10:53 AM
94EG8's Avatar
Seagull Management
Default Re: (coupej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupej1 &raquo;</TD></TR><TR><TD CLASS="quote">i would get one no matter what ecu u are running. </TD></TR></TABLE>
The reason i said you don't need one when running the P08 is because the P08 is the real ECU for the JDM D15B vtec, that engine never came with a purge solinoid, it must be added to the back of the intake manifold if you are using a P28 ECU. or you can use a D16Z6 manifold, both are identical with the exception of the purge solinoid.
Old Jul 13, 2008 | 11:00 AM
obuhmyuh's Avatar
Default Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
The reason i said you don't need one when running the P08 is because the P08 is the real ECU for the JDM D15B vtec, that engine never came with a purge solinoid, it must be added to the back of the intake manifold if you are using a P28 ECU. or you can use a D16Z6 manifold, both are identical with the exception of the purge solinoid.</TD></TR></TABLE>
correct
i believe it wont uphold to some emissions standards though. the p08 is a fairly rare ECU from what I understand, and the p28 will do just fine, if you are using a p08, hooking up a purge solenoid is pointless (p08 isn't looking for one).
I did the same swap, and ended up using my old IM from my z6. My d15b came with a newer IM, when I took my old IM off I saw that the gasket was brand new so i called nippon motors and they told me that these motors were previously carburated (sp).... weird...
Old Jul 13, 2008 | 12:17 PM
94EG8's Avatar
Seagull Management
Default Re: (obuhmyuh)
The earlier non vtec D15Bs came carburated, but all of the D15B vtecs were multiport fuel injection. heres a neat article on the D15B vtec, you've probably seen it before but i just thought i'd throw it in here anyway. http://asia.vtec.net/article/d15b/
twentytwocpb
Apr 23, 2008 07:52 PM
jaycrx
Jan 28, 2007 01:35 PM
JDMdamian95
Nov 1, 2006 03:11 PM
rockthegens
Aug 23, 2005 08:11 AM
oemDC2
Feb 11, 2004 06:40 AM
