GSR/ITR OEM Connecting Rod Bearings: Fancy Coating
Old Jul 11, 2008 | 05:55 PM
stumpyf4's Avatar
Default GSR/ITR OEM Connecting Rod Bearings: Fancy Coating
So GSR/ITR bearings have this fancy coating on the rod bearing, pic below. This fancy coating will be trashed after scraping off the crushed plastigauge. Any problems with scraping off this coating?
Old Jul 11, 2008 | 05:59 PM
Hybrid96EK's Avatar
Default Re: GSR/ITR OEM Connecting Rod Bearings: Fancy Coating (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">So GSR/ITR bearings have this fancy coating on the rod bearing, pic below. This fancy coating will be trashed after scraping off the crushed plastigauge. Any problems with scraping off this coating?
You should not be "scraping" anything off your bearings. Any form of "scraping" that is harsh enough to remove a coating off the bearing is far too harsh. Perhaps you should be a little more careful and come up with a new method to remove the crushed plastigague. You do know that you can leave the crushed plastigauge in there (unless you need to reclearance) and it won't hurt anything, right?
Old Jul 11, 2008 | 07:46 PM
stumpyf4's Avatar
Default Re: GSR/ITR OEM Connecting Rod Bearings: Fancy Coating (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
You should not be "scraping" anything off your bearings. Any form of "scraping" that is harsh enough to remove a coating off the bearing is far too harsh. Perhaps you should be a little more careful and come up with a new method to remove the crushed plastigague. You do know that you can leave the crushed plastigauge in there (unless you need to reclearance) and it won't hurt anything, right?</TD></TR></TABLE>
I haven't plastigauged the rod bearings yet, that one is straight out of the bag and as you can see the coating is very delicate (couple of places where the coating has touched something and flaked off). Hence the my post before I do proceed.
I did not know that the plastigauge can be left on, as this goes again conventional wisdom to keep everything as clean as possible.
Any other opinions/insight out there?
Old Jul 11, 2008 | 07:48 PM
Hybrid96EK's Avatar
Any other opinions/insight out there?</TD></TR></TABLE>
The plastigauge will wear off as soon as the crank is turned after you have torqued the bearings. I have never had an issue leaving the plastigauge on there. To be honest, I do my best to remove the larger sections, but I never scrape the bearings to where I damage the coatings. The initial outter coating on most bearings is very soft and easy to scratch.
Old Jul 11, 2008 | 08:44 PM
count me out's Avatar
* B A N N E D *
that coating does nothing. its from the manufacturing process. will be gone after a few revolutions.
Old Jul 12, 2008 | 07:40 AM
Rocket's Avatar
Default Re: (count me out)
The trick is to make the plastigage stick to the crank and not the bearings. Then there no need to scrape da plastigage off da bearing.
PAM fo da win!!!
Old Jul 12, 2008 | 03:48 PM
stumpyf4's Avatar
Default Re: (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">The trick is to make the plastigage stick to the crank and not the bearings. Then there no need to scrape da plastigage off da bearing.
PAM fo da win!!!</TD></TR></TABLE>
Wish I knew this before I started but anyways the plastigaging went well. The fancy coating dissolves when assembly lube is spread on the bearing.
Old Jul 13, 2008 | 06:41 PM
redlinectr's Avatar
Default Re: (stumpyf4)
A little brake cleaner on those blue shop rags do the trick to, just be gentle and you'll be fine!
Old Jul 13, 2008 | 09:03 PM
stumpyf4's Avatar
Default Re: (redlinectr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinectr &raquo;</TD></TR><TR><TD CLASS="quote">A little brake cleaner on those blue shop rags do the trick to, just be gentle and you'll be fine!</TD></TR></TABLE>
Always told solvents are a no-no for bearings. Oiling the bearing plus scraping with a finger nail FTW. Make sure the finger is clean!!
Old Jul 14, 2008 | 11:38 AM
Mike K's Avatar
i just leave the plasticgage on there. it'll be gone as soon as you start the motor, and it IS oil soluble, so don't be worried.
i wouldn't scrape the bearings, though.
Old Jul 16, 2008 | 01:31 PM
Rocket's Avatar
Default Re: (Mike K)
How guys checking crank fitment (the turn da crizzank and feel resistance by hand) wid da p-g in dere?
Cajuns wanna kno.
RIJMNT
Northern California (Sales)
Dec 4, 2007 07:58 PM
Mugen112
Oct 18, 2006 11:52 AM
kaj
Sep 8, 2006 04:59 PM
marcussmith26
Jan 17, 2006 02:45 PM
Geno
Oct 27, 2004 07:22 PM
