oil sender sensor switch
i start my car every morning and after 2 minutes the oil light comes on. behind my itr block the oil sender sensor leaks out oil threw the pin, is it suppose to do that? also to wire it, can you just hook it up to ground, instead of to the ecu.
Modified by CRX_RR at 3:40 PM 7/11/2008
