want to built a b16 head...let me know if anyone has this setup
Old Jul 11, 2008 | 02:21 PM
poormans_typer69's Avatar
Default want to built a b16 head...let me know if anyone has this setup
ok guys i want to rebuilt my b16 head because right now im pushing 200 whp with gsr block with high compression piston and rods but my head has skunk2 tuners stage 2 and type r valvetrain which is not making the power i really want.... so i spoke to some people and told me to sell the used tuner cams and get
skunk2 pro series cams stage 1
skunk2 retainers and
skunk2 pro series valve spring set
sorry i had to make this a long story but i just want to know if anyone has a head built like this setup or if anyone thinks its ok
Old Jul 13, 2008 | 08:56 AM
Default Re: want to built a b16 head...let me know if anyone has this setup (poormans_typer69)
no one here has this setup
Old Jul 14, 2008 | 02:12 AM
anothersickhatch's Avatar
i had this set-up. what exactly is your question? be specific...
Old Jul 14, 2008 | 01:52 PM
Default Re: want to built a b16 head...let me know if anyone has this setup (anothersickhatch)
is it strong and does it give it great power or just ok...basiclyy is it worth the money
Old Jul 14, 2008 | 02:41 PM
egb18c5's Avatar
what kind of compression are u running?
Old Jul 14, 2008 | 04:24 PM
first off, im not sure why you are even risking using skunk2 stage 2 cams with type-r valve springs and retainers. that doesnt sound too safe over the long run and you definitely do NOT want to drop a valve.
the valve springs and retainers are a good security in itself. those wouldnt be a waste of money.
as for the pro1 cams... if you are looking for more peak hp, the pro1's are bound to give a little more peak hp than the stage 2, depending. just from my experience, my pro1's made around 6 more peak hp. the mid-range power and torque is where the pro1's really shine. if you are looking for more mid range, then go with the pro1's.
just fyi, these cams require a bit more tuning and the idle is lumpy. if i were you, i would replace the springs/retainers anyways and then see where you are from there.
Old Jul 14, 2008 | 06:01 PM
well now i came up with a turbo and do you think i should still rebuild the head...
Modified by poormans_typer69 at 11:06 PM 7/14/2008
Old Jul 14, 2008 | 06:10 PM
paton5g's Avatar
Get your grammar/spelling/typing straight. It's easier when people can actually read your post and then help you. Also, be more specific. We can't read minds.
A lot of people on here won't answer questions if they're difficult to understand.
Old Jul 14, 2008 | 07:05 PM
Default Re: want to built a b16 head...let me know if anyone has this setup (paton5g)
hey my fault... i just type very fast ok everyone has had no complaints...so just chill.. i just want to know if anyone has the setup...skunk2 cams pro1, skunk2 retainers, skunk2 pro series valvespring set, all this in a b16a head.. did i make it more clearly for you...
Old Jul 14, 2008 | 07:28 PM
all-mtr-teg's Avatar
sell your pro1's if your going FI, get yourself some gsr cams.
Old Jul 14, 2008 | 07:51 PM
Default Re: want to built a b16 head...let me know if anyone has this setup (all-mtr-teg)
i have had this set-up and i just told you what i myself have experienced.
Old Jul 15, 2008 | 01:43 PM
thanks bro..i think im going to make my mind up and go boost
Old Jul 15, 2008 | 06:51 PM
DonF's Avatar
Good on you. You seem like a boost kinda guy. Pro-1's actually make really good good boost numbers, like 600+.
Alan.H-EK4
Oct 1, 2013 02:28 PM
sirt_eg
May 19, 2009 01:50 PM
95civickid
Oct 27, 2008 02:52 PM
