tranny gurus - how do you pull the bearings out of the case?
how do you pull the two ball bearings and the single roller bearing out of the case? do you need the special honda tools to do it? also, after you pull them, can you reuse them?
the bearings in the clutch housing need a special tool. i had both of mine pulled from a tranny shop for $10. best $10 i ever spent.
Special tool to pull them, and no, don't re-use them unless you want to take your tranny apart again soon. The pulling process can be destructive at times.
