rear disk swap what master cyclinder
i am doing a swap on my 95 accord and it other forums say to change the master cyclinder to a 4 disk mas. cyc which would be from an ex accord with abs. it dosent make since because im not doing abs just swap of brakes
WHAT DO I DO ....WHICH MASTER CYC. DO I USE
I did the swap on my car from drum to disc and still have the same master cyl. It will work fine. You will need to change out the proportioning valve to one out of a 90-93 integra w/o abs, so your brakes are balanced back out.
KillerHippy
Oct 2, 2010 11:47 AM
