Upgrade the master cylinder with GSR front brake swap?
Hey guys I swapped GSR front brakes on to my CRX HF and I was wondering if I need to upgrade the master cylinder or brake booster for it to work. Can I get away with with leaving everything else stock? Or if not, what else do I need? I've already done the swap just making sure I'm ok before I go ahead and bleed the system.
Btw my OEM master cylinder says 13/16th on it but I've got a second one off the parts car I originally took the GSR swap off of that isn't labeled at all. I can post pics if necessary.
Re: Upgrade the master cylinder with GSR front brake swap?
You can use ANY ABS or NON ABS booster and MC together. You cannot switch ABS booster with NON ABS MC. I have an ABS (290v) booster/MC on one car and a NON ABS (260v) booster/mc on my other car. If you have a GSR that you are swapping your parts from you can use the booster/MC combo.
And the EX MC is crap compared to the 260v and 290v booster/mc setups.
NeverOut215
05-04-2013 04:24 PM
rukawa1one
09-18-2003 05:25 PM
