b16 OBD-2 header?
Old Jul 10, 2008 | 11:46 PM
doom26464's Avatar
Default b16 OBD-2 header?
my bottom part of my header where it is 2-1 part has gotten a masive dent. Im going to go pick up another stock header but its from a obd-2 b16 and mine is a obd-0. they never made any changes to the header did they? should bolt up fine correct?
Old Jul 11, 2008 | 12:04 AM
hotrod99's Avatar
Default Re: b16 OBD-2 header? (doom26464)
yes it will bolt up,all b-series have the same bolt pattern
Old Jul 11, 2008 | 08:48 PM
doom26464's Avatar
ok thnx!
Old Jul 11, 2008 | 09:04 PM
89s1's Avatar
Default Re: b16 OBD-2 header? (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">yes it will bolt up,all b-series have the same bolt pattern</TD></TR></TABLE>
whoa whoa.... you're talking about the flange.
there is a very good possibility that changing just the lower part (B-pipe) will bolt up in the wrong spot. the obd2 motor came from a different chassis with a different stock exhaust location...
I have a junkyard worth of parts at my place and no, they are not all the same in the lower half.
Old Jul 11, 2008 | 09:27 PM
doom26464's Avatar
hmmm so no good then?
deetz84
Dec 4, 2006 09:05 AM
3k9civic
Mar 12, 2005 02:26 PM
GRAVEDIGGER
Sep 16, 2003 11:19 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
