60mm piping-will it bolt up to a 2 inch collecter
96 hatch,b16 swap. b16 header mounts to exhaust in same place but dx motor has cat in header and about a 1 3/4 collecter ,so the exhaust will fit. but will 60mm piping bolt up to the new 2inch collecter on the b16 header.
Re: 60mm piping-will it bolt up to a 2 inch collecter (GRAVEDIGGER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">96 hatch,b16 swap. b16 header mounts to exhaust in same place but dx motor has cat in header and about a 1 3/4 collecter ,so the exhaust will fit. but will 60mm piping bolt up to the new 2inch collecter on the b16 header.</TD></TR></TABLE>
piping will not bolt up to a collector.. you'd need flanges to bolt things together.. .. in other words it'll work if you have the same flange welded on..
Re: 60mm piping-will it bolt up to a 2 inch collecter (sil)
where it connects to header it uses a collecter gasket with a flange that will bolt up to it, just not sure if it will fit with the 2 inch collecter
SantaCruz92Si
07-22-2003 01:57 PM
