wont go into gear except reverse
Old Jul 10, 2008 | 07:21 PM
90goldhatch's Avatar
Default wont go into gear except reverse
my tranny wont go into gear except reverse and when i shoved it in reverse it tried to go back like i disengage the clutch but it was all the way down, i put a new clutch and pressure plate along with my motor swap, but anyways it only goes into gear when the car is off also the pedal is real weak
Old Jul 10, 2008 | 07:45 PM
johnnyonth3spot's Avatar
Default Re: wont go into gear except reverse (90goldhatch)
Your cable isnt tight enough, same thing on my zc swap I did a month ago.
Old Jul 10, 2008 | 07:57 PM
Default Re: wont go into gear except reverse (johnnyonth3spot)
ok ill got try and tighten it, if that doesnt work ill be back
Old Jul 10, 2008 | 08:05 PM
hatcht9x's Avatar
I am havign the same exact problem. but my cable is plenty tight.. my post is right under this.. new clutch..
Old Jul 10, 2008 | 10:42 PM
wow it was my cable i feel friggin dumb that never happened to me, well thanks for the quick replys the hatch says thanks also
sodaZC
Oct 5, 2014 06:57 PM
zapzach
Apr 15, 2013 12:30 PM
felipe69
Mar 19, 2009 11:14 AM
blue89hatch
Nov 19, 2008 09:05 AM
senpai
Apr 30, 2002 01:15 PM
