S2000 throttle body on H22 engine - Will I have install woes and gains?
I've recently bought a S2000 tb for the H22.
I cant find much online and the info I did find, mention some <U>difficulties with the evap signal....</U>
Question 1: How hard is installation and can someone shed some light on the evap problem and how to fix? (98VTEC hint-hint)
Also, I concluded that the main consensus is that an over sized TB would not necessarily produce gains, and that they sometimes cause power loss on a relatively stock engine....
I have pretty significant mods:
Darton sleeves
Mahle 11.5:1 pistons
Eagle rods
Full Crower valve train & stage 2 cams
DSM 450 injectors
RS-R header
Apexi exhaust
test pipe
Iceman CAI
P28 (haven't connected it yet, engine is out of the car for auto to manual tensioner swap, but I will be able to tune with crome to iron out any AF spikes... )
Question 2: Any predictions on gains?
Thanks in advance!
Darton sleeves
Eagle rods
DSM 450 injectors
RS-R header
Apexi exhaust
test pipe
Iceman CAI
Thanks in advance!
1: so no evap problem? just portmatching it and it retains oem functionality??
if so, then cool!!
2: reason for asking any predictions on gains: I opted for the larger tb against hayabusa ITB's because of the fabrications and prolly alot of hassle involved.......dunno if I made the right choice though......
if so, then cool!!
the busa throttles really arent that hard to do if you can spend the money for proper runner fabrication. The biggest problem i had was figuring out how to keep the throttle return springs from popping out of place.
well, lol, i dont have any of that stuff. No evap, no EGR, etc. I was saying it worked perfectly as all i did was bolt it on and everything worked.
