Paint gun set
Old Jul 10, 2008 | 04:07 PM
Bulli Kid's Avatar
Default Paint gun set
http://www2.northerntool.com/product/200310925.htm
Well i have never painted a car before, other then my toy cars with a spray can. but my bros car is getting rusty and crappy, paint is fading ect.. and i would love to repaint it and do the prep work on it. IDk how to deal with the rust though.
Any way Would these spray guns work to paint the car?
lay down primer, base coat, clear coat???
any good sites where i can learn how to paint a car.?
Old Jul 11, 2008 | 09:15 AM
Bulli Kid's Avatar
Default Re: Paint gun set (Bulli Kid)
um any painters in here?
Old Jul 11, 2008 | 09:32 PM
scbmx87's Avatar
For the rust, you're better off just buying patch panels and cutting/welding them in.
Take your time sanding, make sure you get every edge and corner.
Just google "how to paint a car" you'll find something.
I wouldn't recommend that paint gun because i've never heard of the brand.
Check out http://www.autorefinishdevilbiss.com/. They have some decent guns that you can get for around $100.
That's what we're spraying my car with right now, and its looking pretty damn good.
Make sure you get the right tips for primer, base and clear.
I'm pretty sure its a 1.8 tip for primer, 1.5 for base and 1.3 for clear, but read up on it.
Good luck!
Old Jul 11, 2008 | 10:11 PM
bmwpride's Avatar
yea im looking to buy a gun just for a one time job on my car, and maybe some time later use it again... Now out of the ones on the devilbiss site which one do you have and which tips did you get as well
Old Jul 12, 2008 | 03:54 PM
Bulli Kid's Avatar
Default Re: (bmwpride)
these guns can be reused multiple times right?
Old Jul 12, 2008 | 06:15 PM
scbmx87's Avatar
Default Re: (Bulli Kid)
Yeah, you can re use them as many times as u want. Just keep them clean. Run paint thinner through them after each coat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmwpride &raquo;</TD></TR><TR><TD CLASS="quote">yea im looking to buy a gun just for a one time job on my car, and maybe some time later use it again... Now out of the ones on the devilbiss site which one do you have and which tips did you get as well</TD></TR></TABLE>
I have the Finish Line, i got the 1.8, 1.5 and 1.3 tips.
Old Jul 13, 2008 | 10:42 AM
Ivan's Avatar
senior gold member
Default Re: (scbmx87)
I like spraying my clear with a 1.4 tip. I tried the 1.3 and didn't like it.
Old Jul 13, 2008 | 07:10 PM
scbmx87's Avatar
Default Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">I like spraying my clear with a 1.4 tip. I tried the 1.3 and didn't like it.</TD></TR></TABLE>
Really? I was the other way around. Different styles i guess. How'd it turn out? Bumpppp, to get this guy more help!
Old Jul 13, 2008 | 07:24 PM
Ivan's Avatar
senior gold member
well with the 1.3 I would get more orange peel. I can lay out the clear very good with the 1.4. Its just hard cause if I'm not very careful, I'll get a couple of runs but it hasn't happened for a while. 1.3 is better though cause it atomizes better, its just I do better with the 1.4.
Old Jul 14, 2008 | 02:40 AM
nasteawhun's Avatar
hey whats up guys, hopefully i can help yal out on the paint gun issue. the only differance in performance on 1.3 compared to a 1.4 is the spray width pattern. regrardless what tip you use, the gun will always flow the same amount of paint. so since the 1.3 is spraying, lets say 4 to 6 inch pattern, compared to a 6 - 8 inch pattern from a 1.4 tip. the 1.3 is applying more paint in a smaller area. so if your using a smaller tip, make your paint strokes faster. alot of painters from body shop use 1.3 tips to do the job fast and flawless.
Old Jul 16, 2008 | 07:26 PM
bmwpride's Avatar
um i was told it is not a good idea to spray primer and then base from the same gun...?? True??
Old Jul 16, 2008 | 11:45 PM
nasteawhun's Avatar
Not true. the problem is alot of painter dont know how to clean there gun properly and junk will end up in your base. just dont be lazy on cleaning the gun.
Old Jul 17, 2008 | 03:07 PM
Mr. EF's Avatar
Default Re: (bmwpride) (nasteawhun)
i agree with using a 1.4 tip its my favorite so far...those guns should be perfect...its the mixing that gets tricky...when i started my mixing was bad...get tech sheets and messure as close as you can...its not as easy as it looks but fun to learn....leave me an email and ill send you a little Ebooklet on body work and paint basics...its 65 pages written by a 25 year vet on autobody and it help me a lot...
Old Jul 17, 2008 | 05:34 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasteawhun &raquo;</TD></TR><TR><TD CLASS="quote">Not true. the problem is alot of painter dont know how to clean there gun properly and junk will end up in your base. just dont be lazy on cleaning the gun.</TD></TR></TABLE>
people are just lazy
1.4 is perfect for clear and base
Old Jul 19, 2008 | 08:00 PM
bmwpride's Avatar
so if i used one gun but changed the tips would that work fine
Old Jul 20, 2008 | 08:23 PM
integrapunk67's Avatar
Depends on the gun and what it is you're spraying as to what size tip. If i was spraying clear a Sata RP with a 1.2 would rock. Solvent base I'd use an Iwata LPH400 1.3 with the orange cap. Water base I'd use the Sata 3000 HVLP 1.25 WSB
Old Jul 21, 2008 | 04:45 AM
itotech's Avatar
Default Re: (integrapunk67)
^^^^Dude, your using the Bentley's of paint guns. You can't make this kid go buy a $600 paint gun, lol. By the way, how does that gun spray? Kid, if you're going to keep using youe guns for later jobs, get a harbour freight $40 gun for primer, a descent $100-160 base gun, de Villbiss, matco, Sharpe and the same for clear. I have a 1.5 for base and a 1.3 for clear and no prob. what so ever. Check this website: Eastwood.com or Autobodyhelp.com I get a lot of material and products from them and its a free catalog.
Old Jul 21, 2008 | 07:29 PM
Default Re: (itotech)
Dunno where you buy your guns but i can get iwatas for 330-350 new
But hey, its your money, go on ahead and overpay.
Bentleys.... What would a $1500 pressure setup be then?
Old Jul 21, 2008 | 07:54 PM
Jasper_db1's Avatar
Default Re:
I bought a pair of Astro Pneumatic LVLP guns. The primer gun is 1.8 while the base/clear gun is 1.4. The primer gun was very easy to control. I can't wait to try the other one.
Old Jul 22, 2008 | 07:34 AM
itotech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrapunk67 &raquo;</TD></TR><TR><TD CLASS="quote">Dunno where you buy your guns but i can get iwatas for 330-350 new
Bentleys.... What would a $1500 pressure setup be then?</TD></TR></TABLE>Dude relax, i meant $600 for two guns and there are $600 iwatas just in case you didnt know.
Old Jul 22, 2008 | 04:59 PM
bmwpride's Avatar
yea i mean i might spray an other car or bike later down the road but right now i just want my DA to have some color... I was told to buy a harbor freight gun, but wasnt sure.. But thats a good idea but what if i wanted a good name brand gun but not with an outragouse price and a good result.. What would you advise
Old Jul 24, 2008 | 05:39 AM
itotech's Avatar
DeVilbiss, go to autobodymart.com they have em there starting at a little over $100
Old Jul 24, 2008 | 09:53 PM
bmwpride's Avatar
ok thank you do you have a certain model for primer and base and clear
Old Jul 26, 2008 | 08:23 PM
itotech's Avatar
right now i use a harbourgh freight gun for primer, a matco gun for base & clear and i'm getting a devillvis for clear. My matco gun are pretty nice for the price very impress. I think they were like 165 or 175 each.
asocallocal
Paint and Body
22
May 24, 2016 10:19 PM
Cheelee21
13
Dec 14, 2015 06:00 PM
crazyhouse2011
Paint and Body
Oct 21, 2014 10:27 PM
94TealCivic
Jul 12, 2003 04:44 AM
