weird fuel pressure issue after installing injector o-rings
Old Jul 10, 2008 | 02:14 PM
-[95cxhatch]-'s Avatar
Default weird fuel pressure issue after installing injector o-rings
I just replaced the o-rings on my fuels injectors...
Simple install - took off fuel line at the filter and unbolted the rail.
Replaced the o rings and put everything back on.
Now the car won't start!
There are no leaks anywhere...
When I turn the key and prime the fuel pump the pressure goes up to 60psi then steadily drops to about 20.
The under hood pressure gauge is reading around 10-20psi at all times.
My setup is -
AEM fuel rail
Precision 1000cc injectors with GM clips
Honda resistor box with GM connector
Aeromotive Fuel pressure regulator
-6 stainless fuel feed and return lines
Walbro 255lph "HIGH PRESSURE" fuel pump
any thoughts?
Old Jul 10, 2008 | 03:26 PM
Default Re: weird fuel pressure issue after installing injector o-rings (-[95cxhatch]-)
oh yeah.. I'm supposed to be at the tune shop by 9am tomorrow!!!!
Old Jul 10, 2008 | 03:35 PM
eh3 93's Avatar
How many times did you try cranking it over?
Old Jul 10, 2008 | 05:33 PM
probably about 5 times for 5-10 seconds
Old Jul 10, 2008 | 05:34 PM
I waited a few minutes between cranks...trying not to flood it out
Modified by -[95cxhatch]- at 9:05 PM 7/10/2008
Old Jul 10, 2008 | 08:17 PM
Default Re: (-[95cxhatch]-)
*sigh* so much for tomorrow's tune...
Old Jul 11, 2008 | 10:43 AM
Scheizty's Avatar
sounds like a regulator failing. Aftermarket?
Old Jul 11, 2008 | 02:00 PM
it ended up being fouled spark plugs.... fuel pressure seems to be just fine once the car is running.
Thanks for your help!
Old Jul 11, 2008 | 07:43 PM
Tippyman's Avatar
Hmm. How did they foul out while you were changing the o-rings?
Old Jul 11, 2008 | 09:27 PM
I guess they just got to soaked enough to foul them somehow... the car is running super rich so they could have just bit the dust before I even changed the o-rings. who knows weird **** seems to happen very often.
-[95cxhatch]-
18
Jul 11, 2008 02:29 PM
Cyphear
Feb 24, 2007 01:42 PM
midwesta
10
Aug 3, 2005 03:06 AM
Mr. Softee
Jun 30, 2002 12:13 PM
