Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Question about procedures involved in Civic Si strut bump stop replacement (the issue described in o
Old Jul 10, 2008 | 01:50 PM
hahahaha123's Avatar
Default Question about procedures involved in Civic Si strut bump stop replacement (the issue described in o
Hi,
I got my 2008 Civic Si Sedan front strut bump stops replaced under TSB and warranty in the dealership a couple weeks ago and yesterday I suddenly noticed that the passenger side door doesn't quite line up right to the fender (0.5-1 cm difference that I can feel it with my finger) (the passenger door is more indented than the passenger side fender) and I checked the driver side and it is fine. It doesn't have any dent or damage to the door and fender but they just don't line up right. I wonder when the replace the bump stops of the front struts, do they have to remove the fenders to get to it? If so, I will give the dealership a ring about that.
Thanks
Old Jul 10, 2008 | 01:53 PM
MessGSR's Avatar
Default Re: Question about procedures involved in Civic Si strut bump stop replacement (the issue described
lol no, no need what so ever to touch the fender!!
Old Jul 10, 2008 | 02:05 PM
Thanks for the info.
Poor Craftmanship for honda
Old Jul 10, 2008 | 02:20 PM
SIVIC 3's Avatar
.5 mm ? go smoke some more crack.
Old Jul 10, 2008 | 02:35 PM
Default Re: (SIVIC 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">.5 mm ? go smoke some more crack.</TD></TR></TABLE>
0.5 cm - 1 cm
you can definitely feel that
Old Jul 10, 2008 | 04:02 PM
i-VTEC_DOHC's Avatar
be a cheap-o and stuff washers under it? lol
Old Jul 10, 2008 | 05:01 PM
SIVIC 3's Avatar
i thought you posted milimeters but regardless of mm or cm. 0.5 or 1 mm/cm is not noticeable. get your measurements down. you saying honda's build quality is off is ridiculous.
Old Jul 10, 2008 | 09:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 &raquo;</TD></TR><TR><TD CLASS="quote">i thought you posted milimeters but regardless of mm or cm. 0.5 or 1 mm/cm is not noticeable. get your measurements down. you saying honda's build quality is off is ridiculous.</TD></TR></TABLE>
10mm = 1cm so it is 10 times more or less if you take it the other way around. I noticed it when I just looked at it 1 or 2 foot away or looking to the direction of where the fender or door meet when i am leaning on the door. Then I can feel it by touching both the driver and passenger side and compare. Honda's build quilty is going down for sure. At least my 15 years old EG civic doesn't have this problem, in addition, no 3rd gear, sun visors, strut bump stop problems
Old Jul 11, 2008 | 11:19 AM
SIVIC 3's Avatar
honda's build quality isnt going down. your just a douche canoe. go jump off a cliff.
TmeX05
Sep 9, 2007 11:39 PM
mhz2010
Jan 1, 2007 08:42 PM
Pee Wee
Oct 21, 2005 08:49 PM
2.0L EK
May 27, 2005 09:24 AM
Jj0o3eyY
Apr 20, 2005 11:20 AM
