DUPLICOLOR METALCAST? need help achieving anodized look
Old Jul 10, 2008 | 04:38 AM
spray2020's Avatar
Default DUPLICOLOR METALCAST? need help achieving anodized look
well i am trying to use the purple color on my lip on my older rims-
the rims used to have a polished lip-
but i didnt realize that the metal has to stay shiny for it to look anodized-
with out thinking, i sanded the lip with 320 grit so the paint would stick-
but when i sprayed it, the paint just came out looking like normal purple paint
i heard that you can use the "base coat" they make, which is just a metallic silver, and spray the purple over it.
does they really give an anodized look?
anyone have an idea of what to do for this dilemma i have?
thanks alot!
Old Jul 10, 2008 | 07:13 PM
97grnrs's Avatar
Default Re: DUPLICOLOR METALCAST? need help achieving anodized look (spray2020)
it really only works on bare metal thats shiny. i used it on my roll cage and it came out good.. so u can try to paint them chrome and then spray over it with the color but i dunno how good it will work...
Old Jul 14, 2008 | 05:41 PM
hazard2o9's Avatar
well i did this to my rims lip and it turn out great, the best way for u to have that anodize lip is to wet sand ur lip since u already sand it wit 320, work ur way up to 400, 600 and 800 wet sand paper then after that use some kind of polish like mothers to polish it out than thats when u can start painting it, when u paint it use adhesive promoter, its a clean primer for the anodize look then after that use ur anodize paint and it should turn out clean
Modified by hazard2o9 at 11:49 PM 7/14/2008
Old Jul 15, 2008 | 02:00 PM
JDM_CD7's Avatar
Default Re: (hazard2o9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazard2o9 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by hazard2o9 at 11:49 PM 7/14/2008</TD></TR></TABLE>
Using the adhesion promoter does not work.
I've anodized a complete set of wheels by just sanding them and polishing them by hand. Key thing prior to spraying them is cleaning them with alcohol or paint thinner.
Once thats completed then you can start spraying the wheels/lips and then add a engine enamel clear coat for protection.
Ill show you pics of my work soon.
Old Jul 15, 2008 | 04:41 PM
spray2020's Avatar
Default Re: (JDM_CD7)
hmmm,
so when you clean the wheels with alcohol or paint thinner, is this AFTER you polish them?
does cleaning them with either one of those things remove the shine that the polish gives?
Old Jul 15, 2008 | 04:43 PM
spray2020's Avatar
Default Re: (spray2020)
my other prolem is:
i had trouble stripping the clear coat off the lip, without having the stipper leaking onto the gunmetal paint on the spokes (i did tape it off, the stripper leaked through)
Old Jul 15, 2008 | 05:03 PM
SkimN's Avatar
they make a base coat for it, you use this when you are sparing it on something that isn't shiny, don't use chrome paint
Old Jul 15, 2008 | 07:57 PM
hazard2o9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CD7 &raquo;</TD></TR><TR><TD CLASS="quote">
Ill show you pics of my work soon.</TD></TR></TABLE>
well it work for me and if u read on the back of the anodize can it said to use the adhesive promoter
Modified by hazard2o9 at 10:03 PM 7/15/2008
Old Jul 15, 2008 | 08:24 PM
spray2020's Avatar
so you are saying that after polishing the lip with say... mothers aluminum polish-
the adhesion promotor sticks to it? and doesnt bead up?
u guys have mixed opinions- i dont know which to go with!!!
anyone else have a response?
Old Jul 15, 2008 | 09:06 PM
hazard2o9's Avatar
no it doesnt bead up at all, the adhesive promotor like i said is a clear primer, once u spray that on let it sit for a couple of min then spray ur anodize paint...as u see tha picture above its a picture of my rim and thats tha outcome
Old Jul 25, 2008 | 04:39 AM
spray2020's Avatar
well,
i tried out the ground coat they make-
well that stuff sucks!
my question is, if i polish the lip with mothers aluminim polish, can i spray the adhesion promotor right ontop of that?
b/c i know the mothers gives a surface that is very repellent towards water-
if anyone knows, let me know.
Old Jul 31, 2008 | 12:03 AM
slowpokecivic's Avatar
thats why they are telling you to use the adhesion promotor...its not gonna stick to the polished portion, especially if you just polished it...
Old Aug 1, 2008 | 09:54 PM
spray2020's Avatar
Default Re: (slowpokecivic)
thanks for all the help guys
the wheels are turning out great
has anyone used clear ontop of the annodized paint to give more of a glossy look/ protection?
Old Aug 2, 2008 | 12:39 AM
hazard2o9's Avatar
its on u if u wanna spray clear over it but i didnt, i just left it alone...i wanna see pics of it after its done
jdm90civicef
Aug 13, 2014 09:17 AM
SilentEdge
Nov 3, 2007 01:37 PM
.M.
Dec 2, 2004 04:10 PM
Full Race A6
Apr 16, 2004 10:11 AM
Rory Breaker
Jan 31, 2003 07:20 AM
