I thought the D16 didn't have a knock sensor???
Any guesses why then i'm throwing Code 23? Which is the knock sensor?
This happened after I installed hondata gasget. didn't touch the ecu but I did yank the manifold off. is there a sensor or plug on the back of the block I could have messed up which getting to that IM bolt?
thanks!
bryan
thanks!
bryan
I think you just have a trottle position,O2,MAP,Intake Air Sensor. the last 2 being on the manifold-somebody say if they are 100 percent on this
well, i'm about 100% sure the d series don't have a knock sensor... don't know why i'm throwing that code though
yeah, tell me about it. I reset the ecu and drove it again... and got the CEL. pulled over and yup, it's definitely '23' which is
'23 Knock Sensor Circuit'
how could this be? anybody else ever have this problem?
ok, thanks for the tip... but i'm wondering:
do d16y8s come with a knock sensor????
i'm pretty sure the d16z6 don't have one, but what about the 6th gen Ex
[Modified by brcivic411, 7:43 AM 7/22/2002]
when I installed my B16a2, I used my civic harness, and there weren't any left over plugs, and I wasn't short any plugs either
ok, looks like i need to get under the car again to see if i can fix it...
or maybe i just can wait until i put in hondata cause i know the p28 ecu i have doesn't have the knock sensor
btw, for all of you who were scratching your head wondering the same thing. look at the bottom of this post:
https://honda-tech.com/zerothread?id=234054
I'm having the same problem with JDM D16ZC swap with a chipped P28 ECU. Knock sensor CEL. Can't figure out what is causing it.
Have the knock sensor disabled in <CROME> (or whatever you're using) just to make sure. That's usually a default setting when burning basemaps.
T_Rex
27
Feb 12, 2003 07:41 PM
