stock performance suspension??
i have an accord coupe that needs sum new shocks in the back.I want to know if i could replace the shocks for better handling ones that dont make it ride rough but work with the stock setup.
What year is your car? The reason I ask is even if you put $800 on Koni shocks it isn't going to make much of a difference on 15 year old springs. If you want better handling suspension replace the shocks and springs at the same time for best results.
Eibach Pro-kit will give the car a much more sporty feel, while IMO not really degrading ride quality vs stock. GR-2's are an aftermarket stock replacement shock, and I imagine would be your cheapest (quality) replacement.
I don't mean to take over this thread but I need more info!
so I'm looking to buy new shocks and springs
eibach looks nice......so I'm thinking of going lower also
I dont want to lower my ride too much....maybe a good 1\2 or 1 inch drop
I know if I do this its gonna mess with my tire alignment
what else do I have to upgrade to fix this??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radiuslight »</TD></TR><TR><TD CLASS="quote">I don't mean to take over this thread but I need more info!
what else do I have to upgrade to fix this??</TD></TR></TABLE>
Please search. If you had, you'd found that Pro-kit lowers the car about 1.5" front and rear. A standard alignment should be performed after any suspension modification. You won't need a camber kit, as stock adjustments will do just fine because it's not that much of a drop. The Accord FAQ at the top of the forum probably has enough info on suspension to answer all the questions that have been asked here.
honda_joe
Feb 28, 2003 07:50 PM
tFUnK
Jan 24, 2002 10:25 PM
