hard shifting
i have a 1990 accord, 2 door automatic that is shifting very hard threw out driving at times it shifts fine at times not. do you all think that if i get the tranny filter replaced that will fix the problem?also on this car when i give the car gas it has no pick up at take off,but when it gets going it will run great,dont get me wrong if i stomp on the pedal it will go but i dont like to do that.the car is free of any oil leaks,overheating etc. etc. any and all feed back will be used.thanks alot
For the tranny, use Honda ATF-Z1 for the fluid. I used to have harsh shifting with my 96, but after the change, shifts soooo nice. <3 it. =P
For performance, there's lots of things. Maintenance is one of them. Have you done any on the car? Tune-up?
Change your spark plug, wires, air filter, clean out the EGR ports, clean your TB. Look in the Accord FAQ for more info on maintenance.
yeah when i bought the car thats the first thing that i did is give it a real good tune up,plugs,wires,cap,rotor,ignition coil,all filters except the tranny!this was all about a month ago.now im going to try the fluid you refered me too.thanks alot.by the waY is it compicated to change the tranny filter?
I think changing the tranny filter requires you to remove the tranny from the engine. I will say that is complicated. I don't know about the tranny used in the 90's Accord but there is no cover or pan. It's one complete housing.
sony224422
Jan 12, 2006 04:14 PM
D-X-Factor
Nov 16, 2005 09:33 AM
