make my car stop peeing on me
No, I'm serious.
My A/C stinks after I turn it on after it's been sitting for a while. It also sometimes piddles on the front passenger's feet. Today, I took a 55 MPH turn on a 25 MPH exit ramp, and the car leaned strongly to the left. Then, I was met with a gigantic splash of cold, wet water on my ankles. My A/C is pretty ice cold, so I know it works well. What's causing my car to stink and pee on its front passengers? A friend said that it's some sort of clogged drain line from the evaporator. How can I access this? It sounds simple and inexpensive to repair...
all and any advice is wanted and appreciated.
The evaporator case has a drain on it. Yours needs to be cleaned out.
Blow into the drain tube with compressed air.
I'm not sure of the drain tube location for your YEAR & MODEL
There are several types of cleaners on the market to clear the mold from the Evaporator coils.
To prevent mold shut off the A/C and run the fan on high/fresh air for a short while before you shut off the car to help clear moisture from the evaporator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Yamada »</TD></TR><TR><TD CLASS="quote">The evaporator case has a drain on it. Yours needs to be cleaned out.
To prevent mold shut off the A/C and run the fan on high/fresh air for a short while before you shut off the car to help clear moisture from the evaporator.</TD></TR></TABLE>
I've been running it on fresh with the AC off for several mins after I turn the system off for some time now. I also cleared the drain pipe in the evaporator case, as well as removed the crud that had built up there over the past 13 years. I was very thorough. But...
IT'S STILL HAPPENING.
No... water freely comes out of the drain pipe. It's fully clear, for sure.
I have a '96 EX Wagon (so, obviously F22B1, auto, OBD-II). I'm pretty sure all the water has ruined some electronics. My ABS light has gone on and I can hear the door open beep through the stereo speakers (it comes in through the antennae lead, if I unplug that, this won't happen).
So, I've basically set it on recirc so it sucks air out of the foot well into the blower/evap assembly, I never use the A/C anymore (even though it works very well), and have taken off the glovebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhdins »</TD></TR><TR><TD CLASS="quote">The drain pipe might not be connected at all, check that too.</TD></TR></TABLE>
Naw, because it drains onto to ground outside the car.
* B A N N E D *
From: original join date 1/3/07, add 2884 posts, jdm yo
i lol'd at thread title
eurodeseo
Jul 4, 2006 06:55 PM
enthusiast128
13
Feb 23, 2003 01:34 AM
