trying to find out what rods I have
Old Jul 9, 2008 | 02:51 PM
importboi22's Avatar
Default trying to find out what rods I have
I bought some aftermarket LS rods and I can't tell if they are for my LS or not.... can someone measure their rod from the bottom of the pin diameter to the top of the big end diameter.... sorry if that doesnt make sense but here is a little pic for reference.
I got 102.5MM or 4.035"
btw those aren't my rods just a pic for reference
Modified by importboi22 at 4:44 PM 7/9/2008
Old Jul 9, 2008 | 03:42 PM
inspyral's Avatar
If the numbers stamped on them are accurate, those look like stock length LS rods. The full part number on the box should be CRS5394A3D. The 5394 part is the center to center length of the rod(5.394" from the center of the pin end to the center of the big end).
edit: I just remembered that D series rods share the same c-c length as LS rods, so double-check the part number on the box. The LS pin end hole should be .826" in diameter, and the big end should be 1.771" diameter with a width of .935", so you can check those too.
Modified by inspyral at 4:47 PM 7/9/2008
Old Jul 9, 2008 | 03:43 PM
Default Re: (inspyral)
those arent my rods i am sorry.... just a pic for reference.
Old Jul 10, 2008 | 07:13 PM
TunerToys's Avatar
Default Re: (importboi22)
We've listed all of the measurements for Honda application connecting rods, in each of our product descriptions. There are links to each type, here - H-Beam Connecting Rods. Feel fre to click on each link and compare the measurements on your rods, to what we have listed.
Hope that helps,
Craig
__________________________________________________ __________________
[See our posts in the Sponsor For Sale section for deals on...
GARRETT Turbochargers!
HASPORT Motor Swap Products
SEIBON Carbon Fiber
PRECISION TURBO
Widebands / Conversion Harnesses / 3Bar Maps
SEIBON Carbon Fiber
TURBOXS
votoms888
Mar 2, 2011 05:36 PM
B and B
Jan 7, 2009 06:08 AM
HBoy
Jul 21, 2003 04:53 PM
JDMlyfestyle
Jun 26, 2003 08:44 AM
CovertFI
Aug 1, 2002 08:59 PM
