fuel pump noise
Old Jul 9, 2008 | 12:26 PM
blkjak's Avatar
Default fuel pump noise
Does the fuel pump make strange noises when it starts to die
and what do they sound like?
my car makes a strange noise like an idler pulley for ac going bad it does not do it when engine is cold only after engine is at full temperature. the noise seems to be coming from rear of cab but it might originate in the engine compartment.
blkjak....
Modified by blkjak at 1:43 PM 7/9/2008
Old Jul 9, 2008 | 02:30 PM
beana's Avatar
Default Re: fuel pump noise (blkjak)
when your fuel pump goes out they just go out I.E. doesn't do anything at all
what i would do if you don't have power steering pull the belt off take it for a ride if it is still making noise
what you could be hearing is the alternator bearing starting to go out
it it a grind or a whine
Old Jul 10, 2008 | 01:08 AM
blkjak's Avatar
Default Re: fuel pump noise (beana)
thanks - blkjak
Old Jul 10, 2008 | 06:22 AM
bobjohnson's Avatar
Mine makes the same noise. I hear it through the filler neck which is like right behind you in a crx. Almost sounds like metal on metal rubbing. Took me a while to figure out what the hell it was.
Old Jul 12, 2008 | 04:48 PM
blkjak's Avatar
Default Re: fuel pump noise (bobjohnson)
<U>bobjohnson</U> what was it? blkjak
Old Jul 13, 2008 | 04:59 AM
Crx Jimmy's Avatar
it was the fuel pump
Old Jul 13, 2008 | 08:17 AM
beana's Avatar
Default Re: fuel pump noise (Crx Jimmy)
when a fuel pimp is working right you can here it ,it's like a hum ,if theres something wrong with it will grind (i retract my previous statement)
Old Jul 13, 2008 | 09:51 AM
blkjak's Avatar
update - noise stops when a/c compressor is engaged - possible compressor or idler pulley bearing? blkjak
d16z6EG
Jun 30, 2012 11:38 AM
GagnarTheUnruly
Jan 9, 2010 08:54 AM
SlamMan
Apr 12, 2003 01:30 AM
JoshRambo
Mar 17, 2003 08:14 PM
