finally got the witch runnin..
Old Jul 9, 2008 | 07:51 AM
ef dino's Avatar
Default finally got the witch runnin..
9 months... full-wire tuck... some boltons... and the extraction of a turbo kit later i finally get my b16 crx runnin.... BUT once warmed up, she idles at like 3k. So far thats the only trouble i noticed.. And 2 codes. oxygen sensor heater. which can suck my *****, and the IAC code. Which is probably my reason for this high idle issue. How do i go about fixing this code? Or what steps do i take to solve this issue?
thanks in advance!
Old Jul 9, 2008 | 08:02 AM
guy_from_nerk's Avatar
Default Re: finally got the witch runnin.. (ef dino)
pull your iac off the intake manifold, spray it with wd40 or some other form of cleaner, reinstall and see if that helps, make sure you unplug your battery to reset the ecu. If that doesnt help then just get another IAC. If your tuning with Hondata you should be able to go in and adjust the IAC, plus you can remove you 02 sensor with hondata as well
Old Jul 9, 2008 | 08:03 AM
beana's Avatar
change the iac ,but there not cheap
Old Jul 10, 2008 | 10:58 AM
ef dino's Avatar
Default Re: finally got the witch runnin.. (beana)
is there any thing else that would cause a 3k rpm idle? i dont want to replace it if its not the problem
Old Jul 10, 2008 | 11:40 AM
FastEg6's Avatar
Check and see if there are any plugs that should be plugged up in the ntake manifold. I would also check the IAC.
Old Jul 10, 2008 | 10:46 PM
ef dino's Avatar
Default Re: (FastEg6)
say i plug the hole in the throttle body that leads to the IAC. The problem persists. Which means it wouldnt be the IAC as far as my knowledge goes. Am i wrong?
nicwin
Aug 23, 2018 09:21 AM
EfpormantypR
Aug 4, 2009 11:57 AM
reed857
29
Jul 26, 2009 10:57 AM
c0nspire
Feb 23, 2006 02:09 PM
Paluce
Oct 14, 2005 04:07 AM
