200+WHP B20VTEC longblock - New York
200+WHP B20VTEC
2000 B20z block
Wiseco 11.5:1 pistons
Scat Rods
Micro polished B20 crank
2000 B16 head
Port & polished
ITR IM & TB port matched
Crane cams
Spoon cam gears
Supertech valve train
Clutch Master clutch
11lbs Flywheel
Gsr valve cover
Brand new NGK plugs
Brand new OEM timing belt
Brand new OEM water pump
Brand new OBD1 distributor from Distributor King
NOT INCLUDED
NO HEADER
NO TRANSMISSION
NO ECU
NO FUEL RAIL
NO INJECTORS
Motor had a moderate tune and made 221whp and 148trq according to previous owner reving to only 8k. Car pulled hard but could def use a re-tune due to change in altitude and having a cat added on but I never got around to it. Looking for $2,000obo
before
as it sits now
Modified by BoostinEJ1 at 1:05 PM 7/30/2008
2000 B20z block
Scat Rods
2000 B16 head
Port & polished
Crane cams
Spoon cam gears
11lbs Flywheel
Gsr valve cover
Brand new NGK plugs
NOT INCLUDED
NO HEADER
NO TRANSMISSION
NO ECU
NO FUEL RAIL
NO INJECTORS
before
as it sits now
negroeg6
Northern California (Sales)
24
May 18, 2011 03:49 PM
