INPUT NEEDED - Need some help with noise after swap
Old Jul 9, 2008 | 04:57 AM
JokerX-1.6T's Avatar
Default INPUT NEEDED - Need some help with noise after swap
I have been fighting to find a noise in my crx after swapping in a jdm d15 for the last 5 weeks. I have a pretty constant rotational rattle/knocking that can be felt through the floorboard, I have changed the trans 6 times,axles times,and steering rack twice. This has been constant since day one after the swap if you take it out of gear while driving it goes away somewhat I can see nothing that seems to be hitting or touching possibly anywhere and is really noticeable when hitting the brakes almost to the point where I would say that something is being stressed and is not lined up right causing the noise and when in gear is just making it worse. I have chk'd the headers and the exhaust. I am at a total loss and am running out of options on what to try next so any ideas would be helpful. I also swapped in new mounts when doing the swap. I have not had a alignment done yet also but I can also say that the alignment does not seem to be off as I think I did a pretty good job on getting the tie rods at pretty much the same point as before and it drives nice and straight.
Old Jul 9, 2008 | 11:31 AM
playaP's Avatar
Default Re: INPUT NEEDED - Need some help with noise after swap (JokerX-1.6T)
did you align your pressure plate well... maybe try another pressure plate. maybe your starter sticks in the flywheel??
daught
Honda Civic (2001 - 2005)
11
May 13, 2013 03:57 PM
CRISIS
Aug 12, 2006 04:13 PM
NY93CivicEx
12
May 4, 2005 12:28 PM
