piston to wall clearence
I took the block and pistons in today and they micd the block. Was told that it is .003 I looked in manual and mentioned service limits .002 on a stock setup. But did not mention more then that. Is this out of limits? The builder said that they like to see .002 but standard rings should work fine. Just out of curiosity is a little loose ok ?
many factors, but thats a lil too much for cast and a mild all motor build im assuming.
ill run just fine if you put it together, just a little noisy and rings wont last as long
vtec.dc2
Sep 28, 2003 12:19 PM
"WELL PUT MY GOOD MAN"
