can you smog a h23a
Old Jul 8, 2008 | 11:49 PM
andrewdoessucks131's Avatar
Default can you smog a h23a
does anyone know if a "h23a" is smoggable in california. I recently found out from a friend. He checked my enigne and said that the engine code did not match usdm standards and it was a jdm engine.
Cid.
help please..
Modified by andrewdoessucks131 at 1:44 AM 7/9/2008
Old Jul 9, 2008 | 02:04 AM
ethereal2pt2's Avatar
Default Re: can you smog a h23a (andrewdoessucks131)
i don't know about cali but i remember reading that you're allowed to swap engines as long as it's the same size and same series. but it must meet all the requires. you cannot make an obd2 car into an obd1. like for me, i swapped in a 93 h22a which is obd1. but i swapped in all my obd2 components for simplicity as well as emissions. the car & computer doesn't know the difference and neither does the tech who smogs my car. i dont know how thorough testing is in cali though.
Old Jul 9, 2008 | 09:15 AM
Saosinx's Avatar
Default Re: can you smog a h23a (ethereal2pt2)
well in maryland for obd1 cars, they use the sniffer so it doesn't matter what motor you have in your car, as long as it doesn't produce the gases above the certain given allowed amount. i have a jdm h22a and i have an accord type r lip and it sits too low to get on the rollers so i was given a waiver for 2 years. which is good cause i don't think i'd pass lol.
Old Jul 9, 2008 | 09:59 AM
mkazm83's Avatar
Default Re: can you smog a h23a (Saosinx)
If its a Japanese motor it will most likely fail visual. Depends on how attentive the smog tech is. As far as passing the emissions testing, it will depend on what ECU you are running, how mechanically sound the motor is, and if all the proper smog equipment is connected.
What car is this in?
Old Jul 9, 2008 | 01:39 PM
Default Re: can you smog a h23a (mkazm83)
it is in a 93 honda prelude si. the ecu has been programed (not sure what type)
egine sounds great, and it has a a full cat back exhaust.
georgen316
Oct 15, 2013 10:12 PM
Spool This
Southern California
Jun 1, 2011 10:35 PM
Xxcivic97xX
Oct 21, 2010 08:13 AM
accordmatt
Aug 17, 2010 06:24 PM
DX Generation
Jun 14, 2002 01:19 PM
