Where can I get these bearings?
Old Jul 8, 2008 | 08:01 PM
karnieflk's Avatar
Default Where can I get these bearings?
I am doing a motor build and I have clevite p-series bearings right now and the crank measures at .003" clearance across the board. I was wondeirng is I can get ACL's in .001" oversized. Or if there are any place that has bearing that are .001" over the standard sized clevite bearings. If not then what color would it be for the size that is .001" bigger, or is a .003" clearance stlll able to be used even though it is out of spec.
Thanks
Old Jul 13, 2008 | 07:10 PM
redlinectr's Avatar
Default Re: Where can I get these bearings? (karnieflk)
I believe you can get the ACL Race bearings in .001 oversized, check this site out it might help you out.
http://www.tunerschoice.com
Old Jul 13, 2008 | 07:21 PM
mar778c's Avatar
Community Builder
Community Influencer
You can use honda bearings to get the desired clearance.
search under the user Earl in the archives.
goat86
Apr 19, 2014 12:00 AM
boostontheD
Jan 16, 2012 10:42 PM
Charlie Moua
Jan 16, 2012 07:01 PM
sanjay2
Jun 14, 2010 07:21 AM
Eklsv-t
Nov 30, 2007 06:19 PM
