Running Really Rich!
Old Jul 19, 2002 | 12:43 PM
mainelude's Avatar
Default Running Really Rich!
okay I have posted this topic on a few of the other Honda boards and no one has had any good explanations or suggestions for me.
I have a 94 Prelude VTEC with 134.5k on it and under WOT, it spews out a cloud of black smoke that is pretty sizeable. I know cars under WOT do sometimes release black smoke, but I know this is not normal at all. The car seems to run strong and have good power, it dynoed 167 recently. I just want to clear up this ugly black cloud somehow. Could it be an O2 sensor? (my check engine light isn't on). What are the parts I should check and replace to try to clear this up. I changed the plugs this past spring...
Old Jul 19, 2002 | 12:47 PM
WICKED2's Avatar
New User
Default Re: Running Really Rich! (mainelude)
does u'r engine bugs out when its fool throttle
cuz mine does that but i don't see any black smoke caming out on the exhaust pipe
kinesistech's Avatar
I would check the plugs and see if you can determine a source. If you have a leaking injector you should be able to see that from your plugs. Also make sure the vaccum source to the fuel regulator is good.
Old Jul 19, 2002 | 12:59 PM
mainelude's Avatar
Default Re: Running Really Rich! (kinesistech)
How likely is that that it's a leaky injector? What should I look for on my plugs?
Where do I find the vacuum source to the fuel regulator?
Sorry for all the amateurish questions, but doing this kind of work is a little new to me
Old Jul 19, 2002 | 01:00 PM
mainelude's Avatar
Default Re: Running Really Rich! (WICKEDII)
my engine runs perfectly, I just have a black cloud.
itsmike
10
Apr 4, 2005 10:16 PM
GDM Z28
Jan 25, 2005 08:45 AM
toooslow
Mar 9, 2003 08:26 AM
TEGME
Oct 16, 2002 01:05 PM
echo999
Jan 12, 2002 03:43 PM
