pg6b pistons ?
d15b2 engine the pistons im using are pg6b they have a small dome so im guessing that would make them sit up higher then pm3 which are flat now what i want to know is will my valves hit i also have a stage 2 cam 110 intake 104 exhaust and with a piston that has a dome i thought it would raise the compression
really the only thing you can do is clay the motor and find out...heres a wrie up on how to do it http://www.c-speedracing.com/h...y.php
