s300 with hi/low boost switch and pwm controlled
Old Jul 8, 2008 | 09:08 AM
civicboy96's Avatar
Default s300 with hi/low boost switch and pwm controlled
i have a s300 installed into my p28 ecu and also have the pwm components istalled for boost control. as of now it its set up to send out a signal from the a11 pin. i know it is possible to have a switch to select between hi and low boost settings, after properly tuning to the highest boost level i will be at of course, but do not know where to hook this switch up to/in-between what wires? Thanks Jake
Old Jul 8, 2008 | 09:16 AM
mtber's Avatar
Default Re: s300 with hi/low boost switch and pwm controlled (civicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">i have a s300 installed into my p28 ecu and also have the pwm components istalled for boost control. as of now it its set up to send out a signal from the a11 pin. i know it is possible to have a switch to select between hi and low boost settings, after properly tuning to the highest boost level i will be at of course, but do not know where to hook this switch up to/in-between what wires? Thanks Jake</TD></TR></TABLE>
Yes this is possible.
Old Jul 8, 2008 | 09:25 AM
civicboy96's Avatar
Default Re: s300 with hi/low boost switch and pwm controlled (mtber)
i know its possible, but with what wires and how to hook it up?
Old Jul 8, 2008 | 10:07 AM
Spunkster's Avatar
You have to look at the software and under boost control you will have to select and input and connect it to a switch to activate high and low boost.
Old Jul 9, 2008 | 05:28 PM
norconex's Avatar
Default Re: s300 with hi/low boost switch and pwm controlled (Spunkster)
The HELP in the software is pretty good too...
13g-crx
Engine Management and Tuning
Dec 28, 2016 06:29 PM
jv88_dc2
Jun 12, 2012 03:49 AM
bb6kid22
Nov 1, 2010 05:03 PM
civicboy96
Aug 21, 2008 08:03 AM
boostincoupe
Jan 7, 2005 01:17 PM
