Omni LCA's on EJ6 won't take ITR rear sway??
I've had these omni lca's for a long time on my 96 hatch and I decided to put on a subframe brace and rear sway. I finally got around to putting it on and noticed the holes in the lca for the sway bar endlinks are about two inches away from where the bar actually sits.
Anyone else dealt with this. The only options I see are drill two new holes in the lca for the sway bar - which I like best because then I don't have to buy anything, but is it safe??
Or buy new lcas, or I guess an Omni sway bar??
Any ideas about the drilling a hole idea?
But you should be able to get the endlinks from anywhere. If you need to order them from http://www.iapdirect.com I bought mine from them and it included the endlinks, bushings and all h/w.. The website doesn't have everything they carry, you'd be better off calling them tomorrow. I ordered my stuff and went and picked it up the next day.
Modified by 96civic_hb at 12:40 AM 7/9/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20EF »</TD></TR><TR><TD CLASS="quote">^^Thanks for the help, my shop said ASR is on backorder so I'll have to get blox though</TD></TR></TABLE>
im not talking about endlinks. im talking about the little spacers that go in the hole of the swaybar. you can even use oem 99-00 Si endlinks if needed.
