help!! i want to make my b20 a little more reliable
have any suggestions on what steps i should do to keep my b20b going? its overheated a few times and i beat on it sometimes, nothing serious. im pulling the codes today for sensors but just wantd to know anything else can i do?
Uh, make sure your cooling system is up to it? do you have the proper size radiator, hoses, new coolant, fans working etc. general maintenance.
i've never understood posts like these.
you do realize your motor was designed to last for thousands of miles right?
you also have maintenance recommendations that came with the car.
so how about take care of the obvious things, and follow the manufacturers recommendations.
yes i understand the maintainence part but inm sure honda didnt build b20's to be swapped into a delsol and ran off a chipped p28 with a redline of 7200 so im sure the block has takin on some ware i guess the propper way to put it is what should i replace or strengthn to insure my motor will last
