Rear disk conversion- need some advice
Old Jul 7, 2008 | 10:01 PM
94CDMeg's Avatar
Default Rear disk conversion- need some advice
I was wondering what is needed to swap disk brakes from a 93 Si onto my 94 eg hatch that currently has drum brakes.
I have been doing some research and looking for threads on this topic.
Do i need a new prop valve, m/c, or anything else?
The guy im buying the brakes from said it was the "complete rear end disk" so im pretty sure its from the splash guard out
and also are there any tips to help me do this conversion?
thanks
Old Jul 8, 2008 | 03:57 AM
94EG8's Avatar
Seagull Management
Default Re: Rear disk conversion- need some advice (94CDMeg)
If your rear discs are off a '93 just swap the both trailing arms as a unit, your also gonna need the flex hoses and parking brake cables from the Si. In your case you wont need the proportioning valve or the master cylinder as they are the same as what you already have. if you upgrade to larger front brakes you will need the master cylinder and proporting valve though. As for tips, expect to break bolts off, ask whoever your buying the swap from for all the bolts he took out and didn't break and when your putting everything together put lots of neverseize on bolts going through suspension bushings, it'll make your life a lot easier if you ever have to take anything apart again.
Old Jul 8, 2008 | 12:33 PM
94CDMeg's Avatar
Default Re: Rear disk conversion- need some advice (94EG8)
ok thanks man.
can i not use the parking break cable from my drum brakes tho?
because he isnt sure if he has that specific one. he said he can get a cable off another civic.
Old Jul 8, 2008 | 12:39 PM
OMGWTFBBQ!'s Avatar
You can NOT re-use your ebrake cable. You need to get an ebrake cable from a car with rear discs.
Old Jul 8, 2008 | 12:50 PM
slvrcvc93's Avatar
Default Re: (OMGWTFBBQ!)
x2 drum and disc cables are completely different
Old Jul 8, 2008 | 01:09 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! &raquo;</TD></TR><TR><TD CLASS="quote">You can NOT re-use your ebrake cable. You need to get an ebrake cable from a car with rear discs. </TD></TR></TABLE>
X3, ideally you'll want the parking brake cables of an Si hatch, but any '90 - '00 civic or integra parking brake cables from a car with rear discs will work.
Old Jul 8, 2008 | 01:46 PM
94CDMeg's Avatar
Default Re: (94EG8)
sorry i didnt know they werent the same.
how hard of a job is installing a new parking break line? sorry. never done it before.
am i going to have to install everything again from the lever back?
Old Jul 8, 2008 | 02:19 PM
OMGWTFBBQ!'s Avatar
Frankly, its a bitch. You have to remove your center console, and pull up your carpet to get to the e-brake connections. You also have to remove your gas tank guard to get to the cable mounts on the chassis under the car.
Old Jul 8, 2008 | 02:52 PM
94CDMeg's Avatar
the interior stuff shouldnt be a problem. and im pretty sure i can use a car lift at a local exon (friend works there).
any other problems yall can see ill hit when i do this swap?
thanks for the help
Old Jul 8, 2008 | 03:00 PM
EL Vap133's Avatar
Default Re: (94CDMeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CDMeg &raquo;</TD></TR><TR><TD CLASS="quote">the interior stuff shouldnt be a problem. and im pretty sure i can use a car lift at a local exon (friend works there).
thanks for the help
No, unless you don't have all the parts, and/or rusted or stripped bolts. other than that all you need is elbow grease and you'll be set.
Old Jul 8, 2008 | 03:12 PM
94CDMeg's Avatar
Default Re: (EL Vap133)
ok thanks everyone. been a big help. im getting everything tomarrow and hopefully starting on it too.
ill post if anything goes wrong.
thanks
Old Jul 9, 2008 | 11:36 AM
94CDMeg's Avatar
umm the prop valves arent the same tho.(from the 93 civic si and my 94 civic cx) i checked the part #'s out.
is this a problem? i dont want the balance getting messed up and the back wheels getting braked too much and mabe locking up...
Old Jul 9, 2008 | 12:13 PM
shifty35's Avatar
Make sure you get an alignment immediately afterwards, before your rear tires get trashed.
Old Jul 9, 2008 | 12:18 PM
EL Vap133's Avatar
I personally don't think it matters, but if you want to be proper use the 4040 prop valve.
Old Jul 9, 2008 | 01:42 PM
94EG8's Avatar
Seagull Management
From what i got out it the reason most cars with rear discs was because they also came with front brakes. I have a friend with a '92 civic Si hatch, came from the factory with rear discs, no ABS, hers came from the factory with a 13/16 master cylinder and 3035? i belive proportioning valve, not sure on those numbers as i really couldn't get my head in far enough to look, but i did go to honda and cross reference that car ('92 Si) with my car ('94 LX sedan that came stock with rear drums) and they are the same. So, to sum up, if you have also upgraded your front brakes use the 4040 prop valve and master cylinder, if you have only added rear discs use the original prop valve and 15/16 master cylinder. I never changed my master cylinder or prop valve and i haven't had any trouble at all, and i drive in snow for like 5 months a year, on top of that my front brakes are pretty much worn out so the rears almost should be locking up, front rotors are original honda from '94 and very, very worn out. i think its time for a nice set of brembo blanks.
Modified by 94EG8 at 2:53 PM 7/9/2008
Old Jul 10, 2008 | 02:34 PM
94CDMeg's Avatar
Default Re: (94EG8)
ok ill try it. its just the valves arent the same. heres the 93 si http://www.hondaautomotivepart...81%29 look at Illustration # 7 on the parts list and the 94 cx. http://www.hondaautomotivepart...81%29 and again its #7
but even if they arent the same im going to do it. i take your word on the not sliding...
ha and yeh id love a big break kit but $$ is a problem...
thanks
Old Jul 10, 2008 | 02:42 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CDMeg &raquo;</TD></TR><TR><TD CLASS="quote">ok ill try it. its just the valves arent the same. heres the 93 si http://www.hondaautomotivepart...81%29 look at Illustration # 7 on the parts list and the 94 cx. http://www.hondaautomotivepart...81%29 and again its #7
thanks </TD></TR></TABLE>
yes the valves are different. the 4040 valve you need and is a direct bolt on are found on 92-93 integras and 94 non abs integra.
you have a better chance of finding one out of a 92-93 integra at a yard, maybe even ebay.
Old Jul 10, 2008 | 03:22 PM
94CDMeg's Avatar
Default Re: (philosofy1)
philosofy1 so your saying i should upgrade the prop valve and 94EG8 is saying i dont need to.
i read that the 4040 gives less fluid to the back because the rear disks dont need as much as drums.
so which is it? haha
K-G
Suspension & Brakes
Aug 4, 2019 08:31 PM
Show15
Suspension & Brakes
15
Apr 6, 2010 10:05 AM
Repodevil
Jun 30, 2005 01:35 PM
EGhatched
10
Mar 31, 2004 08:45 AM
HXMan
Aug 19, 2001 07:24 PM
