need 2 line up cams and crank ect...
Get a manuel for your car. Or search. You can most likely find a manuel for your car online. There are a ton of posts about setting cam timing. We can't help you without basic info such as.....
What motor is it? Is it stock? If not stock, what's done to it? Has it ever been rebuilt?
What was the last thing done to it before the timing belt broke?
Do a compression and leakdown test to check for bent valve I'm petty sure.... but you have to install timing belt correctly before leakdown test gives correct results.
turbodawg629
Mar 11, 2009 08:26 PM
Thrillhouse
Aug 9, 2004 02:47 PM
