I love turbo...
Old Jul 19, 2002 | 10:34 AM
93LSivic's Avatar
Default I love turbo...
Especially when my IC piping blows off of the compressor housing and my arm hits the turbine housing.
Makes me want to buy some of the firesleeves found at Summit and keep in the glovebox.
Had to do a roadside fix. How many of you guys did the same thing?
Old Jul 19, 2002 | 10:36 AM
Smashback's Avatar
Default Re: I love turbo... (93LSivic)
Yep, after I got the 3 inch exhaust done the thing was spooling so fast it would blow the piping apart every time i got on it. I had it all welded and used JB Weld to make rings around the ends of the pipes and haven't had a problem since.
Old Jul 19, 2002 | 10:40 AM
Mentat Ghola's Avatar
Default Re: I love turbo... (mplex2000)
its happend a grip of times in my eclipse. vary anoing. how ever you spell it. but no i have never rested my arm on the turbine housing. haha retard. JK i have although been curios enough to touch it an burnt my finger hehe couldnt resist.
-mitsuman not hatchedsi
Old Jul 19, 2002 | 10:41 AM
ceemarun's Avatar
how much are you guys boosting for the IC piping to pop out like that?
Old Jul 19, 2002 | 10:42 AM
Default Re: I love turbo... (ceemarun)
^^ 8psi
Old Jul 19, 2002 | 10:57 AM
Adi Radoncic's Avatar
On Fire!
Default Re: I love turbo... (HatchedSI)
Two Words you guys!!
T-bolt Clamps!!!!
adi
Old Jul 19, 2002 | 11:02 AM
VaporTrail's Avatar
New User
Default Re: I love turbo... (newgsr)
two more :bead welding
Old Jul 19, 2002 | 11:04 AM
Full-Race Geoff's Avatar
that is too funny, i have an identical burn but on my right wrist. same spot and all, but mine is from welding, and deciding that a hot manifold would be an ideal place to set my wrist... smells like hamburgers, pretty gross
Old Jul 19, 2002 | 11:06 AM
Smashback's Avatar
Default Re: I love turbo... (VaporTrail)
Yeah way more important than those expensive *** T bolts. Guys are running tons more boost than be without T bolts so I figure I can get away with my 8-10 PSI with good ABA clamps.
Old Jul 19, 2002 | 12:56 PM
The Mick's Avatar
I've had to make that same emergency stop once, too. After that, I doubled up on the ss worm-gear style clamps until my ss t-bolt clamps came in.
BTW, they're not that expensive... @ $3.95.
Of course, this is assuming you are buying other stuff at the same time, 'cause if not, that $7.95 "handling fee" will make it less of a bargain.
http://store.summitracing.com/defaul...rchType%3DBoth
Old Jul 19, 2002 | 02:06 PM
GSRwBOOST's Avatar
Default Re: I love turbo... (The Mick)
Had mine pop off a few times.. then i got a nut driver and tightened them things down so tight it made a virgin look like a widemouth Grolsch bottle...
Old Jul 19, 2002 | 03:35 PM
lucas569's Avatar
Default Re: I love turbo... (GSRwBOOST)
so you think w/ a nut driver it will be fine? what size clamps would one need anyhow 2" to 2.5" ? or bigger?
Old Jul 19, 2002 | 03:49 PM
W.Zero's Avatar
id use better clamp like turbonetics, str, aebs, all make clamps that should take care of your problems. but im using regular clamps that come with the drag kit boostin 17lbs and on the bottle and i never had that problem.
Old Jul 19, 2002 | 04:35 PM
SIK IN DA HED's Avatar
New User
Default Re: I love turbo... (W.ZeroB18C1T)
how did that happen?
Old Jul 19, 2002 | 05:07 PM
BoostinDC2's Avatar
Default Re: I love turbo... (dlplayboy)
just use 2 hose clamps.
ityab0y
Nov 7, 2005 04:44 PM
jdm-ray
Sep 8, 2005 09:45 AM
turbotime
Jun 28, 2003 09:47 AM
Integra_Boi
Jul 26, 2002 08:59 PM
saso
Jun 6, 2002 04:28 AM
