help needed ASAP "DASH LIGHTS"
Old Jul 7, 2008 | 02:21 PM
ONE-CAM-EF's Avatar
Default help needed ASAP "DASH LIGHTS"
so my dash lights dont want to work. well they work when they want to like its not bright as it used to like it dims away. and some times well most of the time they dont work period..\ i though it was a fuse but if they are still turning on it cant be that...can it be my alternator going bad or something?? well any help would be nice...
Old Jul 7, 2008 | 03:01 PM
ONE-CAM-EF's Avatar
can someone help a boricua out..lol..
Old Jul 7, 2008 | 03:55 PM
ArtyG's Avatar
Default Re: (ONE-CAM-EF)
I think you'd have other symptoms of a failing alternator if it was truly that. Have you checked the dimmer switch? Maybe that little sucker is failing you or getting stuck on one setting somehow.
I would double-check that little guy first, after that, make sure your connections are 100% in place...could be a loose connection as well resulting in inconsistent/sporadic connection.
mglcrls09503
Feb 8, 2010 12:09 AM
sh3d3vilinme
Lighting
Feb 13, 2009 04:16 AM
HondaKid936
13
Feb 12, 2008 11:11 AM
neb11ihtut
Jul 19, 2007 12:29 AM
VTECtravler
13
Oct 4, 2006 07:51 AM
